Atmega328pb-au-nd
Hello Arduino forums,
I accidentally bought 5 atmega328pb-au-nd not knowing that the atmega328p-au is different.
Am i still able to use this for arduino?
I saw this thread
which just was saying that the memory is a bit lower, but they don't answer the question of is it still usable? Am I losing something other than memory ?
The pinout is showing the same.
Thanks,
xzarida:
You sure are. You'll need to install and use Minicore, and just be careful of the slight pin differences between the 328P and 328PB.
So i noticed that pin 3 is pe0 and pin7 is pe1 is pin 6 now instead of vvc and gnd.
If I am not using PE1, and PE0 it just means two less connections right ?
because I only need D3 D4 and D9 D10 for the project i want.
Yes, that's right.
