atmega328PB sleep mode programming; help please
Hello,
I created a pcb, which I’ve mentioned on other threads. I initially built the project using a 328P and using rocketscream sleep lib, I got the current consumption down to 150uA. Now that I’ve used the 328PB, the lowest I can get the consumption during sleep mode is 5mA, using a fork of rocket screams lib for the PB. Which is a massive difference for a battery powered project.
I came across this AVR example and building the simple led circuit, which reduced the comsuption to about 25uA. So what I am trying to achieve is possible but I’m having to go down the actual programming route, rather than libs and I do not have a clue, I can not get it to work.
https://microchipdeveloper.com/8avr:low-power-example
This is my code, using the forked lib;
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
//#include <DHT.h>
//#include <LowPower.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include "LowPower328PB.h"
//#include <LowPower328PB.h>
#define power2_h
#define __AVR_ATmega328PB__
//#define DHTPIN 2
//not all #defines used but here for documentation
#define CE_PIN   7
#define CSN_PIN 8
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
// define device I2C address: 0x76 or 0x77 (0x77 is library default address)
#define BME280_I2C_ADDRESS  0x76
Adafruit_BME280  bme280;  // initialize Adafruit BME280 library
//added for cal adjustment
const float adjustment = -1;
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
//#define DHTTYPE DHT22
struct data
  float temperature;
  float humidity;
} sentData;
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 2000;
//DHT dht(DHTPIN, DHTTYPE);
unsigned long delayTime; //added last 12/08/19
  Serial.println("SimpleTx Starting");
  radio.begin();
  radio.setPALevel(RF24_PA_MAX);
  radio.setDataRate( RF24_250KBPS );
  radio.setChannel(124);
  radio.setRetries(3, 5); // delay, count
  radio.openWritingPipe(slaveAddress);
  //dht.begin();
    Wire.begin();
  //dht.begin();
  while(!Serial);    // time to get serial running
  Serial.println(F("BME280 test"));
  bme280.begin(BME280_I2C_ADDRESS);
//bme280.setTempCal(-1);
  delayTime = 5000; //added last 12/08/19
  currentMillis = millis();
  if (currentMillis - prevMillis >= txIntervalMillis)
    sentData.temperature = bme280.readTemperature() + adjustment;
    sentData.humidity = bme280.readHumidity();
    send();
    prevMillis = millis();
void send()
  bool rslt;
  rslt = radio.write( &sentData, sizeof(sentData) );
  if (rslt)
    Serial.println("  Acknowledge received");
    Serial.println("  Tx failed");
  delay(50);
//works for A and B below
//Loop for 6 times (48 seconds between temprature transissions)
  for (int i = 0; i < 6; i++)
//A - From pro mini code - doesn't work here
//    LowPower.idle(SLEEP_8S, ADC_OFF, TIMER2_OFF, TIMER1_OFF, TIMER0_OFF,
//                  SPI_OFF, USART0_OFF, TWI_OFF);
//B - works from LowerPower328PB lib - power not reduced much
    LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
//C - lib
This is the example code, which I tried to integrate
 * lowpower2.c
//#include <avr/io.h>
#include <avr/io.h>
#include "avr/interrupt.h"
#include "avr/wdt.h"
#include "avr/sleep.h"
#include <avr/power.h>
#include <avr/interrupt.h>
//#include <util/delay.h>  //maybe use this for delay instead of count
void    optimize_power_consumption(void){
    /* Disable digital input buffer on ADC pins */
    DIDR0 = (1 << ADC5D) | (1 << ADC4D) | (1 << ADC3D) | (1 << ADC2D) | (1 << ADC1D) | (1 << ADC0D);
    DIDR0 |= 0xC0 ;   /*ADC7D and ADC6D are undefined in header file so set bits this way*/
    /* Disable digital input buffer on Analog comparator pins */
    DIDR1 |= (1 << AIN1D) | (1 << AIN0D);
    /* Disable Analog Comparator */
    ACSR |= (1 << ACD);
    /*Power shutdown to unused peripherals*/
    PRR0 = 0xDF;
    PRR1 = 0x3F;
    /*Unused pins set as input pull up*/
    DDRB &= 0xE0;
    DDRC &= 0xC9;
    DDRD &= 0x03;
    DDRE &=0xF3;
    PORTB |=~(0xE0);
    PORTC |=~(0xC9);
    PORTD |=~(0x03);
    PORTE |=~(0xf3);
    /*Watchdog Timer OFF*/
    /* Disable interrupts */
    cli();
    /* Reset watchdog timer */
    wdt_reset();
    /* Clear WDRF in MCUSR */
    MCUSR &= ~(1<<WDRF);
    /* Turn off WDT */
    WDTCSR = 0x00;
    /* Set sleep mode */
    set_sleep_mode(SLEEP_MODE_PWR_DOWN); ///////////
                                TMR 0 Initialization
 void TMR0_init( void ){
    // enable timer overflow interrupt for both Timer0 and Timer1
    TIMSK0=(1<<TOIE0) ;
    // set timer0 counter initial value to 0
    TCNT0=0x00;
    // start timer0 with /1024 prescaler
    TCCR0B = (1<<CS02) | (1<<CS00);
    // enable interrupts
    sei();
     uint8_t    count;
/* Timer 0 Interrupt */
 ISR(TIMER0_OVF_vect){
    count++;
    if(count==20){
        count=0;
        // Toogle LED
        PORTB=PORTB ^ 0x20;
ISR (PCINT0_vect)
     if (!(PINB & (1<<PINB2))) // if PINB7 is low (Switch pressed)
        PORTB |= (1<<PORTB5); // Turn ON LED
        PORTB &= ~(1<<PORTB5); // Turn OFF LED
int main(void)
    TMR0_init();
    DDRB |= 1<<DDRB5;   // Direction of pin PB5 set as Output
    DDRB &= ~(1<<DDB2); //Set PORTB7 as input
    optimize_power_consumption();
    PCMSK0 |= (1<<PCINT2); //Enable Pin Change Interrupt 7
    PCICR |= (1<<PCIE0); //Enable the interrupt enable bit for PCINT
    sei();
    //set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    //sleep_enable();
    //sleep_cpu();
    /* Replace with your application code */
    while (1)
        sleep_mode();
Any help, advice or pointers. I’ll happily pay for some coding expertise :slight_smile:
This is what I was using for the 328P, which worked a treat.
