Hello!
I'm trying programming my atmega32A with my arduino uno and arduino ide 1.8.13 on linux mint. I found this https://www.instructables.com/Burning-Arduino-Bootloader-to-Atmega-32A-PU-Using-/ and the bootloader is burning but after i can't upload any program to the Atmega32A. Anybody have a good guess what is the problem? I want to use with 16mhz external oscillator the chip, but it wrong with 8mhz internal settings too.
I checked the pins many times, not the christal and not the arduiono as an isp pinout is a problem.
Bootloader burning output:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/smv/.arduino15/packages/MightyCore/hardware/avr/1.0.8/avrdude.conf"
User configuration file is "/home/smv/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 10 64 0 no 1024 4 0 9000 9000 0xff 0xff
flash 33 6 64 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
efuse 0 0 0 0 no 0 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9502 (probably m32)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "{bootloader.extended_fuses}"
avrdude: writing efuse (0 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 0 bytes of efuse written
avrdude: verifying efuse memory against {bootloader.extended_fuses}:
avrdude: load data efuse data from input file {bootloader.extended_fuses}:
avrdude: input file {bootloader.extended_fuses} contains 0 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.00s
avrdude: 0 bytes of efuse verified
avrdude: reading input file "0xd6"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd6:
avrdude: load data hfuse data from input file 0xd6:
avrdude: input file 0xd6 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0b10111111"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0b10111111:
avrdude: load data lfuse data from input file 0b10111111:
avrdude: input file 0b10111111 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
AVR Part : ATmega32
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "/home/smv/.arduino15/packages/MightyCore/hardware/avr/1.0.8/bootloaders/optiboot_flash/atmega32/optiboot_flash_atmega32_115200_16000000L.hex"
avrdude: writing flash (32768 bytes):
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against /home/smv/.arduino15/packages/MightyCore/hardware/avr/1.0.8/bootloaders/optiboot_flash/atmega32/optiboot_flash_atmega32_115200_16000000L.hex:
avrdude: load data flash data from input file /home/smv/.arduino15/packages/MightyCore/hardware/avr/1.0.8/bootloaders/optiboot_flash/atmega32/optiboot_flash_atmega32_115200_16000000L.hex:
avrdude: input file /home/smv/.arduino15/packages/MightyCore/hardware/avr/1.0.8/bootloaders/optiboot_flash/atmega32/optiboot_flash_atmega32_115200_16000000L.hex contains 32768 bytes
avrdude: reading on-chip flash data:
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0f"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
But if i'm trying upload a sketch:
avrdude: Expected signature for ATmega32 is 1E 95 02
Double check chip, or use -F to override this check.
I choose the good settings for the MightyCore so Atmega32, external 16Mhz, Bod 2.7v, Standard pinout, Arduino as isp programmer.
Thx you for your help!
