Hi Everybody,
I know there is a lot of documentation online where you can read up how to set all timer-registers like
TCCR1A
TCCR1B
TCNT1
OCR1A
etc.
for invoking the timer-interrupt in certain intervals.
Does somebody know if there exists a library where you call a function with a parameter
where this parameter is the ISR-frequency and the function will setup all the registers required in the correct way.
I am aware that not each and every frequency can be adjusted so the function could give back a -1 for not working at all and positive number representing the deviation between value of the parameter and the real frequency
best regards Stefan
