ATmega32U4 to Arduino
Hello,
I have created a custom PCB with a factory version of the ATmega32U4 which I would like to flash with an Arduino program. I've created an Arduino sketch to interface with a UART device and successfully tested it on an Arduino. However when I program the same sketch onto the custom PCB with factory ATmega32U4, the UART communications don't work. I am able to have the ATmega32U4 print to the Serial port and read it with my computer. I have updated the fuses to match the Arduino Leonardo. Is there anything else that I'm missing that is necessary to flash a brand new ATmega32U4?
Thanks for your help!
Mike
Hi Mike,
Welcome to the Forum.
The 32U4 has an onboard USB to serial converter to talk to your computer (via the serial monitor, I presume you are referring to that). That connection is addressed as Serial, you say it works fine.
When you now connect a UART device, via Arduino pins 0 and 1 (physical pins 20 and 21 on the chip) which I presume you are, you need to use Serial1 to talk to the connected device.
Hope that addresses your problem.
Willem.
