ATmega64 Arduino code not responding(Not Executing) Done with Bootloading And uploading
Need help for uploading the code in ATmega64 which made for ATmega2560 , There is no pin toggling happening.
How should i make it run for 64 Please anyone suggest .
Need help seeing the code.
"Not Executing"
How do you know?
If you want to write code for the ATmega64, you need a core, that supports the ATmega64 processor. E.g. this one.
Anything else is a gamble. It may work or not.
The 2560 has much more peripherals and flash/ram.
Thank you @anon73444976 Issue was solved.
Thank uou @MicroBahner Issues was solved.
