Hello all,
So, I just got a couple Atmega8 in the mail and wanted to upload some test code. Well first thing I did was check the signature and fuse states in avr. All good. So then I went in to the arduino software to see if I could upload the arduino bootloader. I made sure to select the atmega8 in the board section and attempted to upload the bootloader. It threw an initialization failure exception. I tried checking the state in avr and now avr is giving the same error. Any ideas on what could have caused this? Would I be able to correct the chip?
scotte2718:
Do you have a 3rd party hardware package installed that supports ATmega8?
Do you have a crystal attached?
scotte2718:
Post the full output when you try to burn bootloader in the Arduino IDE. Please use code tags(</> button).
pert:
I am using the stock hardware package included with Arduino software
pert:
No, I do not have a crystal attached. I just have it directly connected to my avr programmer and nothing else.
pert:
Here is the output
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
scotte2718:
What board do you have selected in Tools > Board?
Try doing Tools > Preferences > Show verbose output during upload and then if there is more output when you do Burn Bootloader post it here.
I'm not one of the resident experts in figuring these sorts of issues out so I may not be able to provide a solution but at least I hope to help you provide sufficient information to get your chip working.
The board I have selected is the Arduino NGor older/atmega8. Here is the verbose output.
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega8 -cusbtiny -e -Ulock:w:0x3F:m -Uhfuse:w:0xca:m -Ulfuse:w:0xdf:m
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 15:55:32
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/scott/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 001:007
AVR Part : ATmega8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [ac 53 00 00]
CMD: [ac 53 00 00] [ff ff ff ff]
this check.
avrdude done. Thank you.
I think the problem is that since the Arduino NG has an external 16MHz crystal the low fuse setting burned when you did the first Burn Bootloader configured your chip to use an external crystal so this "bricked" your chip but not to worry, you can fix it by connecting an external clock source and then do Burn Bootloader again with the low fuse changed to, for example, 0xE4 if you wanted to use the internal RC oscillatory at 8 MHz. You could do this by connecting a crystal or I think you can use another Arduino as a clock source. There is some information on this in the Chip not detected section of Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board.
scotte2718:
I think you should be using decoupling capacitors and a reset pin pull-up resistor though you might be able to get away without it's just more potential causes of problems.
Just got around to testing it. That was the problem. Appreciate the help.
