ATmega8 Vs Atmega328P
Hi there !
I have a sketch which is working fine with ATmega328P, since this uc is expensive, I would like
upload this program/sketch to ATmega8. I have the following apprehensions :-
(1) Is it possible to upload this sketch to ATmega8 ?
(2) If uploaded ,will it work without problem ?
(3) If it malfunctions with ATmega8, What changes I need to do ?
Warm Regards
Read this before posting a programming question
Hard to say, without seeing this sketch.
To determine if your sketch will potentially work on an ATmega8 select the 'Arduino NG or older w/ ATmega8' board type in the Arduino IDE and try to verify the sketch. If it verifies without problems then your a long way to getting it to work. If it shows errors then you will need to post your errors so people can see what the problem may be and if it's fixable.
Quick and easy check - good idea Riva.
