Hello. I have loaded the arduino bootloader on the ATmega8 and ater I load the sketch it runs smooth.
The sketch is a "Hello World" LCD test.
After a couple of days the program does not load at all and I need to re-upload it, but the bootloader is fine.
I use a 16MHz crystal with 2 18pico capacitors, 100nF capacitor on the VCC to GND close to the uC, 100nF capacitor on the AVCC to GND also close to chip, 7805 regulator with 220uF on the 12v side and 100uF on the 5v side along withn 100nF ceramic caps.
The pin1 is connected to 10Kohm resistor and the resistor to the +5v.
I don not know where is the problem, and I dont know what to do. Is there some way to "lock" the uploaded code?
Can you suggest me some solution ?
Thank you
