Problem:
Error while uploading: missing 'upload.params.quiet' configuration parameter.
I bootloaded atmega8l-8pu as per the link using Arduino as ISP(windows 7 user)
i am using arduino as ISP to bootload and it completed without showing any error AND then i replace the atmega328 with atmega8 for uploading purpose.I have tried usbasp,avrisp. What should i use?
i have set the fuses as shown in the link.
Can you guide me What things do i have to check thrice?
I followed the procedure correctly so i think everything is right but i dont have knowledge of fuses and lock bits for now.Can i have enough knowledge of them by reading datasheet?
Also what does the error :missing 'upload.params.quiet' configuration parameter point to?
I added some upload parameters in the boards.txt file ,tell me if i missed some imp parameters.
i tried on older version arduino1.0.3 and the error now is:(i am using atmega8l-8pu)
avrdude stk500_getsync() not in sync resp=0x00 .
Its a very common error but i am not able to remove it.I also tried changing upload.protocol to arduino in the boards.txt file.
I tried older 0022 too and it shows the same error :
Can I bootload the same chip twice? It would be nice if anyone can share a link of more trustworthy bootloader for atmega8 for 8 mhz .I dont want to use crystal or other external components.
Thanks
Yes you can bootload the same chip twice or many many times!, in under arduino\hardware\arduino\bootloaders\atmega8 you can change certain parameteros of the C source file to support a certain clock source and use the INTROSC @ 8Mhz ,seems like your best best right now.
