ATMEGAP-PU bootloader
Hello arduinofolks!
I'm trying to burn a bootloader to an atmega328p-pu(yes it says p-pu on the chip) via an arduino uno as ISP.
ISP sketch loads perfectly to the arduino.
Then I hook up the atmega like the minimum config. In the arduino tutorial.
BUT I keep the arduinos original atmega on the arduino uno and I don't have a crystal so I skip that. I try to burn bootloader with arduino software 1.0.1 with both arduino uno and "ATmega328 on a breadboard (8 MHz internal clock)" checked in the boardmenu.
I then try the newest arduino software and do the same thing but just gets the error message saying:
"avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check."
I then try to change signature in case it happened to be an atmega-pu but it didn't work.
What to do?
Thanks for the help!
Dude, your post is not very clear, please go slowly and repost, but here are some comments.
The -PU suffix simply designates a DIP package, like the socketed 28 pin on the Uno.
A 328P is a 328P regardless of the package. There is also a plain 328, which would be labeled 328-PU for the DIP socket.
If you don't have a crystal, you must change the fuses.
Post the detailed error to show the signature it reports.
You have to have a crystal.
[edit] Read this tutorial by Nick Gammon: Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
You might need a crystal for the target chip before you can even change the fuses.
From Gammon's tutorial:
[As an alternative to a crystal or resonator, the revised version of the sketch outputs a 8 MHz clock on pin D9 of the programming board. Thus you just need to connect D9 on the programming board to pin 9 of the target board and this will provide a clock signal, enough for you to upload the bootloader and change the fuses./quote]
Thanks for your replies! And I'm sorry for the unclear post I'll try to clearify it.
1, I have an atmega328p-pu and the seller didn't say if a bootloader was burned or not.
2. So I want to burn a bootloader to the atmega with arduino as ISP.
3.I upload the ISP sketch to my arduino UNO, no problems.
4. I connect my UNO and the atmega like this but leave the original unos atmega on the arduino.
5. I try to burn the bootloader in two different arduino IDEs(1.0.1 and the newest one) with both the boardoption "Arduino uno" and "ATmega328 on a breadboard (8 MHz internal clock)"
6. In both cases I get this error:
       this check.
  1. I read that if it's a plain atmega328 you have to change the signature arduino expects from the atmega, I try that, doesn't work.
  2. Okay I need a crystal, is there a workaround if you don't have one? As you mentioned Pegwatcher, D9 from my arduino to pin9 on the atmega?
    Thanks once again, you guys rock!
Yes, you seem to have a handle on it. BUT you must use the revised version of the programmer sketch (Atmega_Board_Programmer) that you will find a link to on Gammon's site. This revised sketch puts out that 8 MHz clock on pin 9. Just follow Gammon's instructions. It works!
I beg your pardon, Archelon, that piece of code is already in the Atmega_Board_Programmer that comes with the IDE. At least, it is in the sketch that came with my IDE 1.0.6
I didn't realize that.
So you should already have that 8 MHz clock output available.
The relevant code snippet in setup():
// set up Timer 1
TCCR1A = _BV (COM1A0); // toggle OC1A on Compare Match
TCCR1B = _BV(WGM12) | _BV(CS10); // CTC, no prescaling
OCR1A = 0; // output every cycle
Gave the atmega the 8Mhz signal from the arduino according to gammons tutorial and everything went fine! Thanks for the help guys! You know these things :wink:
Forward towards other solutions!
