If you install via board manager or manual install by extracting the manual installation version of the board package into the hardware folder inside your sketchbook it should "just work"
If you are following some old (obsolete) installation guide that involves modifying files in the arduino installation folder, instead of sketchbook/hardware folder or using boards manager, thats the only thing I can think of that could result in things like that.
You're sure it's not just that there are enough entries in the boards menu that it's scrolling? (There will be little arrows at the top and bottom of tools -> board menu in that case - scroll wheel on your mouse while mouse above opened tools -> board menu will also work)
I'm thinking that there might possibly be a problem with how you've saved the links to the two different cores- I should have asked, in between switching which core you're using (TinyCore or MegaCore) are you changing anything in the 'Additional Board Manager URLs' field?
BJHenry:
Yes sure. To install the other Boards I have to change the link in Additional Board Manager URLs field. And then... the other Boards are gone
So, I can only have one type of Boards, ATiny or Atmega16
FreeWorks:
The good news is, that is very easy to fix. Open File -> Prefences again, and hit the button here:
