I took an Atmel 24C256 (8-pin SOIC, I2C EEPROM) from an old Nokia 5120, and soldered it to a protoshield (with SMD pads), properly connecting it to SCA, SCL, GND, +5V.
All the 2 address pins are tied to GND, and so is the "write protect" and NC pin. This should have made the EEPROM appear at address 0x50, but it is not.
Using a sketch called i2cScanner (see below), I was able to see it is in address 0xE8. the problem is that writes to that address always return "success", but nothing is read afterwards.
I've tried writing/reading at address 0x50, 0x51 but nothing works. I am using the common I2C EEPROM routines found in the "Playground" and several other sites.
Any tips on what I shoud do next or how to fix that?
i2cScanner.ino:
// i2c_scanner
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// This sketch tests the standard 7-bit addresses
// from 0 to 127. Devices with higher bit address
// might not be seen properly.
// Adapted to be as simple as possible by Arduino.cc user Krodal
// June 2012
// Using Arduino 1.0.1
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 0; address <= 254; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(8000); // wait 8 seconds for next scan
