Atmel Studio 6.0 and Due
Hi Guys
I am trying to write the code for a simple blinking led on arduino due using the ATmel studion 6.0 and gcc compiler.I able to compile the code but the led is not blinking
#include <asf.h>
void delay_ms(unsigned int delay) {
	while (delay--) for(int x=0; x<0x3FFF; x++) __asm__("nop\n\t");
#define led 1<<27
int main (void)
	unsigned int i;
	sysclk_init();
	board_init();
	PIOB->PIO_OER =1<<27;
	while(1)
		 PIOB->PIO_SODR=led; // turn the LED on (HIGH is the voltage level)
		 delay_ms(1000); // wait for a second
		 PIOB->PIO_CODR=led; // turn the LED off by making the voltage LOW
	// Insert application code here, after the board has been initialized.
This code is not working and led is not blinking.Can anybody help me with sample code and program.
Regards
Gopalakrishnan.N
Hi
I got the answer from the ARMguy post.
The problem has been solved
