Hello Everyone,
I am having the worst possible experience trying to work with atmel studio 6 and am looking for a bit of help.
I am using Atmels avrisp mkII programmer to try and burn the arduino bootloader onto some atmega328P-AU and atmega328-AU chips, I have both.
I am running avr studio 6 on windows 8 beta through VMfusion as I don't have access to any windows machines.
After finally getting atmel studios to connect to the avrisp mkII and update the firmware I tried to read the chips through their isp connection and couldn't get a reading. I figured that the chips may have been bad due to messing with the avrisp on a mac trying to burn the bootloader through the arduino software so I replaced the chip with a brand new one (Atmega328P-AU).
With the new chip I was able to get a good reading on the chip and everything worked fine, I programed the optiboot into the chips flash and everything was still okay. I then went to program the fuses to 0xFF LOW 0xDE HIGH and 0x05 Extended. When I clicked program fuses I received the error "command failed due to previously failed command" then I get a message saying it cannot enter programming mode. Now I cannot read the at all anymore. I tried on another atmega328P-AU chip but this time didn't program the bootload, I read the chip, everything was fine, went to set the fuses, same error.
I was successfully able to program an attiny85 chips fuses with no issues whatsoever.
Does everyone have a hard time working with the avrisp mkII, there seems to be a lot of people running into issues with it?
If anyone was any advice on getting this to work it would be much appreciated.
Nick D.
