Does anyone tried to program those chips on a breadboard with an arduino code?
Here is what I did:
I bootloaded this chip like I did with an atmel8. everything was ok.
-I replaced this chip with an atmel8 on the breadboard which I made sure was working fine. (I tried and programmed the atmel8 without changing it with atmel168) . -
I compiled the same program, change the settings in the arduino>tools> microcontroller(MCU)>from atmel8 to atmel168, tried to upload it to the chip, I got a programmer is not responding error.
I changed the setting to atmel168 to atmel8 in the tools>microcontroller(MCU)>atmel8. I tried to program it again, it didn't work.
I changed my clock on the circuit from 16mhz to 20 mhz to see if that was the problem. it didn't work.
do you guys any recommendation for me?
thanks alot.
