I'm trying to install the bootloader on a stand alone Atmel328P chip following instruction othe tutorial:
this is the message that the l'IDE 1.6.13 reply me:
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
In a previous topic I read that Nick Gammon made a specific sketch in:
What is the the sketch i must upload on arduino board?
Thank you in advance
sarouje
December 15, 2016, 6:39am
#2
Can you please provide the photograph of your connection?
Hope you uploaded Arduino ISP sketch to your Arduino board.
DrAzzy
December 15, 2016, 7:18am
#3
If you're getting that error, it sounds like you've got ArduinoAsISP uploaded to the board correctly.
Enable verbose upload and see what signature it's seeing. 0x000000 indicates that either the connections are wrong, or the chip is set to use a crystal, but no crystal is present.
I copied this from kubuntu terminal:
/home/mscaglione/Scaricati/arduino-1.6.13/hardware/tools/avr/bin/avrdude -C/home/mscaglione/Scaricati/arduino-1.6.13/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3, compiled on Sep 12 2016 at 15:21:49
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/mscaglione/Scaricati/arduino-1.6.13/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/mscaglione/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Errore durante la scrittura del bootloader
this check.
avrdude done. Thank you.
In the italian forum gpb01 suggested me a guide.
I substituited the chip of an Arduino board and connected it with another Arduino board as thescribed in pag 15 of the guide
It worked
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/home/mscaglione/Arduino/hardware/breadboard/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex"
avrdude: writing flash (32652 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32652 bytes of flash written
avrdude: verifying flash memory against /home/mscaglione/Arduino/hardware/breadboard/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex:
avrdude: load data flash data from input file /home/mscaglione/Arduino/hardware/breadboard/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex:
avrdude: input file /home/mscaglione/Arduino/hardware/breadboard/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex contains 32652 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: 32652 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: 1 bytes of lock verified
I attach a file showing connections
sandie0
December 19, 2016, 3:02am
#7
its a connection issue check that crystal is added with capacitor or not
