AtmelStudio 6.2 and Arduino 1.8.13
Hello,
I always have used AtmelStudio 6.2 in combination with Arduino 1.0.5 And this works very well.
But now i would like to use the FastLed library and i can't get it working on the 1.0.5 IDE.
So i downloaded the 1.8.13 IDE as a stand alone, so i can use the 2 IDE's. This works well and the FastLed library works also good in the new IDE.
But in AtmelStudio i can't get the FastLed to compile well.
I have seen that i was still using the 1.0.X in AtmelStudio. So now i'm trying a new 1.5.X in combination with the 1.8.13 IDE setup, but this goes wrong.
This is what i have done:
I made a second External Tools setup.
Title:
Arduino IDE 1.8.13
Command:
C:\Program Files (x86)\arduino-1.8.13\hardware\tools\avr\bin\avrdude.exe
Arguments:
-CC:\Program Files (x86)\arduino-1.8.13\hardware\tools\avr\etc\avrdude.conf -v -patmega328p -carduino -PCOM8
-b115200 -D -Uflash:w:"$(ProjectDir)Debug\$(TargetName) .hex":i
But i get an error when i compile something with this setup.
Error:
Compiling 'NeoPixelRing' for 'Arduino Uno'
	Process: "{runtime.tools.avr-gcc.path}\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=1813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\Program Files (x86)\arduino-1.8.13\hardware\arduino\avr\cores\arduino" -I"C:\Program Files (x86)\arduino-1.8.13\hardware\arduino\avr\variants\standard" "C:\Users\Moondust\AppData\Local\VMicro\Arduino\Builds\NeoPixelRing\uno\NeoPixelRing.cpp" -o "C:\Users\Moondust\AppData\Local\VMicro\Arduino\Builds\NeoPixelRing\uno\NeoPixelRing.cpp.o"
Error compiling
And when i change between the 2 IDE setups i also do a Reload Toolchains.
So, what did i wrong in my setup. Because i did the same with the old IDE and that works just fine.
Best regards
