atoi FAIL
Hey everyone!
I am trying to recieve multiple bytes over serial, store in array, and use atoi to convert to int. However I am getting very different results from atoi :(
Using atoi like this: if( Serial.available() >= 3 ) { rred[0] = Serial.read(); rred[1] = Serial.read(); rred[2] = Serial.read(); char * thisChar = rred; int a = atoi(thisChar); }
Attaching a pic of terminal, so you can se what it outputs. gratisupload.dk/download/45675/
As you can see, it works after sending 000 command some times, but only once.
Please help!! :D
Best regards, Jonas Hald
char    buffer[4];
if ( Serial.available() >= 3 )
    char*   pbuffer = buffer;
    *pbuffer++ = Serial.read();
    *pbuffer++ = 0;
    int     n;
    n = atoi(buffer);
Or, if you're averse to explicit pointer arithmetic and extraneous variables:
char    buffer[4];
    buffer[0] = Serial.read();
    buffer[1] = Serial.read();
    buffer[2] = Serial.read();
    buffer[3] = '\0';
    int     n;
    n = atoi(buffer);
Thank you very much!! :D Both of you!
The short answer is you can do:
You'd have to use strcpy or something else to copy the array to the other one.
He already is doing that - what's your point?
There's nothing wrong with the code in the OP, except there's no "rred[3] ='\0';" before the "char * thisChar = rred;" (assuming "rred" is declared as having at least four elements.)
