I was intend to use timer interrupt for limited instances of a class in my ESP32 Arduino project, my first code conception was as follows
typedef void (*irqCallback) (void);
irqCallback timerCBArray[] ={ timerCB0 };
void ARDUINO_ISR_ATTR timerCB0(){
portENTER_CRITICAL_ISR(&lock0);
//manipulate class private and public variables
portEXIT_CRITICAL_ISR(&lock0);
hw_timer_t * timer[3] = NULL;
class myClass
private:
irqCallback timmerCB;
volatile uint8_t pri_var1,pri_var2;
static uint8_t class_instance_number=0;
public:
volatile uint8_t pub_var1,pub_var2;
myClass(/* args */);
~myClass();
myClass::myClass(/* args */)
timmerCB=timerCBArray[class_instance_number];
timer[class_instance_number] = timerBegin(0, 80, true);
timerAttachInterrupt(timer[class_instance_number], &timmerCB, true);
class_instance_number++;
however, I came to this problem, how can I change the variable inside the interrupt regards to each class instance
any help really appreciated
