Attaching Interrupt to an Array?
Hello everyone,
So I am working on one of those SumoBots and I have 4 IR sensors that are used to detect a change from black floor to white floor. I am using QTR-1RC and its library. The example codes used an array to store their multiple sensors in.
The problem is, whenever one of these sensors detects a change in color, it should immediately stop what it's doing and move away from the line, so I figured an interrupt would be perfect. However, I am trying to reference a specific pin from the array to send it to a specific method. Unfortunately, the code will not compile. It gives this error message:
SumoRobot:63: error: macro "digitalPinToInterrupt" passed 3 arguments, but takes just 1
attachInterrupt(digitalPinToInterrupt(sensorValues[0], retreat, FALLING);
exit status 1
#define numSensor 4 // number of line detectors attached
#define timeOut 2500 //waits 2500 microseconds for sensor outputs to go low
#define emitterPin 27 //emitter is controlled by digital pin 27
// line sensors 0 through 4 are connected to analog inputs 18 through 21, respectively
QTRSensorsRC qtrrc((unsigned char[]) {18, 19, 20, 21},numSensor, timeOut, emitterPin);
unsigned int sensorValues[numSensor];
void setup () {
P.S. I am using a Mega 2560
it was a freaking close parathesis after sensorValues[0]. I have been pulling my hair out for hours now. Fml
But did it work after closing the bracket?
dsb0025:
Did you have to revive an old thread? I always wonder how people manage to find them.
OP is obviously happy as he/she did not come back in this thread.
Do you have the same problem? Or have something to add?
sterretje:
I’m sure its better to revive an old one with new information for the benefit of all. Perhaps in a mkore constructive way tough.
I had the same problem, the error message is a bit obscure.
The correct syntax for this handler is
attachInterrupt(digitalPinToInterrupt(pin mode), handler, mode);
on the code above this would translate to
attachInterrupt(digitalPinToInterrupt(sensorValues[0]), retreat, FALLING);
