attachInterrupt, blink led for 1 seconds than shutdown
Hi to all!
I'm studying the interrupts.
My sketch is looking for a button pressed. If yes, blink a LED for 1 seconds than shutdown.
The only part that doesn't function is that the led never shutdown.
How I can shutdown the LED after 1 second?
You will find also a code part to bypass the debounce.
You will find also some Serial.println. I have in serial also the words ""Lo stato è HIGH!" , so my code read correctly that the new state of PIN is HIGH, but it doesn't write to LOW.
Thank you for your support!
const int LED_PIN = 8;
volatile int state = LOW;
long previous_millis = 0;        // will store last time LED was updated
long interval = 1000;           // interval at which to blink (milliseconds)
long debouncing_time = 1500; //Debouncing Time in Milliseconds
volatile unsigned long last_micros;
// the setup function runs once when you press reset or power the board
  welcome();
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_PIN, OUTPUT);
  attachInterrupt(0, debounceInterrupt, RISING);
void welcome() {
  Serial.println("Benvenuto!\n");
void debounceInterrupt() {
  if((long)(micros() - last_micros) >= debouncing_time * 1000) {
    blinkLed();
    last_micros = micros();
// the loop function runs over and over again forever
  digitalWrite(LED_PIN, state);
  unsigned long current_millis = millis();
    if( (current_millis - previous_millis) > interval) {
      previous_millis = current_millis;
      Serial.println("Il tempo è passato");
      Serial.println(state);
      int current_state = state;
      if (current_state==HIGH) {
        Serial.println("Lo stato è HIGH!");
        digitalWrite(LED_PIN,LOW);
void blinkLed() {
  Serial.println("Button pressed!");
  state = !state;
EDIT:
Found the "bug" or the programming error. I did not re-chage the volatile state.
This is my code, just to tell you.
if( current_millis - previous_millis > interval) {
    if (state==HIGH) {
      state = !state;
      digitalWrite(LED_PIN,state);
In general, don’t call a function from within your ISR like this - it is the same as including the code directly in the ISR
    blinkLed();
In your particular case your function calls Serial.print() which requires interrupts and in an ISR interrupts are disabled. Even if that was not a problem Serial.print() is a slow function that would delay the completion of the ISR. An ISR should be designed to complete as quickly as possible.
In this case your ISR could be
    readyToBlink = true;
and then the code in your blinkLed() function could be
void blinkLed() {
  if (readyToBlink == true) {
     readyToBlink = false;
     state = !state;
and just call blinkLed() from loop()
I am assuming this is just a learning exercise and that you know it is not necessary to use an interrupt to detect a human pressing a button.
…R
