Here is the issue : ScreenChoice should increase each time i push the button. But it increses twice, when I touch the button and when I lift my finger.
Hmm... Perhaps the device shows the equivalent of "switch bounce". If so, there might sometimes be more than two changes with one touch or one release.
Riva:
What happens if you turn on the internal pullup resistor.
pinMode(3, INPUT_PULLUP);
Nothing has changed
jremington:
Does ScreenChoice always increment by exactly 2?
You are true, I haven't noticed that as my "true" code is a bit different, but most of the time it increase by 3 or 4, and rarely by 2 and more than 4, but never by one.
It does sound like the equivalent of switch bounce. Most likely, there is a comparator measuring voltage levels, and noise on the input line causes multiple transitions on the output.
There are lots of posts on this forum, and even a library to deal with switch bounce.
// Setup the button with an internal pull-up :
pinMode(BUTTON_PIN,INPUT_PULLUP);
// After setting up the button, setup the Bounce instance :
debouncer.attach(BUTTON_PIN);
debouncer.interval(5); // interval in ms
// Update the Bounce instance :
debouncer.update();
// Get the updated value :
int value = debouncer.read();
It seems easy to use, but, how do i can implement it in my :
attachInterrupt (1, button_push, FALLING);
EDIT2 :
Maybe I should do it this way :
but, i will have to train to determine the debouncing time which fit the best!
