attachInterrupt is not working properly with IR Remote and an Linear Actuator
Hello everyone,
I have been struggling to implement an attachInterrupt (on Arduino Uno Digital Pin 2) with a IR Receiver Diode (TSOP38238) and an Linear Actuator (https://www.aliexpress.com/item/100mm-4inch-Stroke-Heavy-duty-1500N-330lbs-Load-DC-12V-Electric-Linear-Actuator-5-7mm-s/2020556667.html?spm=2114.13010608.0.0.1XAV0C). The remote controller I'm using to send IR signal uses NEC protocol and the linear actuator is controlled by a Polulu VNH5019 Motor Driver Carrier (Pololu - VNH5019 Motor Driver Carrier).
SYSTEM DESCRIPTION:
  • MacBook Pro macOS Sierra (10.12.4)
  • Arduino Uno
  • Arduino IDE (1.8.3 Hourly Build 2017/04/26 01:12)
OBJECTIVE:
I want to open and close a mini chamber by controlling the actuator's stroke length. When the chamber closes, I want to take measurements every two seconds and print the result via serial monitor. I'm using the IR remote controller to send a specific signal to close and open the chamber.
PROBLEM:
I can open and close the chamber by sending the specific signal. It also takes measurements, display on serial monitor but during measurement, if I send a chamber open command it does not execute and continues to take measurements (stuck in the loop; interrupt does not work??).
SETUP:
IR Receiver Diode VS --> +5V (Arduino)
IR Receiver Diode GND --> GND (Arduino)
IR Receiver Diode OUT --> 2 (Digital Pin Arduino)
VNH5019 INA --> Arduino Digital Pin 5
VNH5019 PMW --> Arduino Digital Pin 6
VNH5019 INB --> Arduino Digital Pin 4
VNH5019 VDD --> Arduino +5V
VNH5019 GND --> Arduino GND
VNH5019 OUTA --> Linear Actuator (BlackWire)
VNH5019 OUTB --> Linear Actuator (RedWire)
VNH5019 GND --> External Power Supply
VNH5019 VIN --> External Power Supply (12/5A)
WORKING CODE:
#define samplingInterval 2000UL             // Sampling delay in ms, can be adjusted.
//Required libraries
#include <IRremote.h>
const byte irPin = 2;
const byte INB = 4;
const byte INA = 5;
const byte PMW = 6;
IRrecv irrecv(irPin);
decode_results results;
const byte sensorPin = A0;
unsigned long currentTime = 0;
unsigned long previousTime = 0;
boolean chambOpen = false;
void setup () {
  Serial.begin(19200);
  pinMode(irPin, INPUT);
  pinMode(INA, OUTPUT);
  pinMode(PMW, OUTPUT);
  pinMode(INB, OUTPUT);
  attachInterrupt(digitalPinToInterrupt(2), checkIR, CHANGE);
  irrecv.enableIRIn();
void loop () {
  if (results.value == 16753245) {  //Opens chamber
    setDir(1);
    slide(10000);
    chambOpen = true;
  else if (results.value == 16736925) { //Closes chamber
    if (chambOpen = true) {
      setDir(2);
      slide(10000);
      chambOpen = false;
    while (chambOpen == false) { //Stuck here?
      currentTime = millis();
      if (currentTime - previousTime > samplingInterval) {
        previousTime = currentTime;
        Serial.print("Sensor Reading: ");
        Serial.println(takeSensorReading());
//Takes sensor reading
float takeSensorReading(void) {
  float sensorValue = 0.0;
  //sensorValue = analogRead(A0);
  return sensorValue;
//Interrupt ISR
void checkIR(void) {
  while (irrecv.decode(&results)) {
    irrecv.resume();
//Sets actuator's stroke direction
void setDir(int d) {
  switch (d) {
    case 0: // off
      digitalWrite(INA, LOW);
      digitalWrite(INB, LOW);
    case 1: // forward
      digitalWrite(INA, HIGH);
    case 2:  // backward
      digitalWrite(INB, HIGH);
    case 3:  // locked?
//Sets stroke length
void slide(int d) {
  for (int v = 0; v < 256; ++v) {
    analogWrite(PMW, v);
    //delay(d);
    delayMicroseconds(d);
  for (int v = 255; v >= 0; --v) {
    //delay(d);
I don't have electronics background. I'd really appreciate if someone can point me what's wrong I'm doing here. Thank you for your time to read the post.
In the loop:
      setDir(2);
      slide(10000);
      chambOpen = false;
is changed to:
if (chambOpen == true) {
      setDir(2);
      slide(10000);
      chambOpen = false;
The problem is still there... :frowning: Thanks for your attention.
