attachInterrupt only working sometimes?
Okay, I have a program that has a routine in the loop() that calibrates my circuit. Before I start calibrating, I detach both interrupts because I'm using pulseIn(). After my calibration routine, I attach my interrupts again. Problem is that only one of my interrupts will attach. It doesn't matter which order I attach or detach them in, it will always only attach the interrupt for pin 2.
The other odd part about this is, if I comment out the lines for the interrupt, compile, then uncomment, compile, both interrupts will work as they should. Below is a snippet of my code. Note, I do not attach or detach anywhere else in code.
if(mode == CALIBRATION_MODE)
    detachInterrupt(0);
    detachInterrupt(1);
    turnOffAllOutputs();
    Serial.write("Calibrating\n");
    digitalWrite(calibrateLED,HIGH);
    digitalWrite(readyLED,LOW);
//    calibrateResult = calibrate();
    calibrateResult = quickCalibrate();
    if(calibrateResult >= 0)
      offset = calibrateResult;     //Set global offset
      Serial.print("Offset: ");
      Serial.print(offset);
      Serial.print("\n");
      mode = COMMUNICATION_MODE;    //Change to communication mode
      lastCommTime = millis();
      digitalWrite(calibrateLED,LOW);
      digitalWrite(readyLED,HIGH);
      attachInterrupt(1,sendComm,CHANGE);
      delay(100);
      attachInterrupt(0,receiveComm,CHANGE);
      //delay(100);
Any ideas would be greatly appreciated. -Jeremy
How do you know?
Because when the second interrupt catches I should be turning on an LED when the signal goes high. I’ve watched the signal on an oscilloscope and it is changing like it should but I get no change in my LED. I’ve manually tested my circuit outside of the interrupt so I know electrically, it is fine.
Has anyone else seen this issue?
-Jeremy
P.S. Currently, as a workaround I took out the detach and moved the attach to setup(). This isn’t the best workaround because I use pulseIn() and the interrupt will mess with this.
The code for attachInterrupt / detachInterrupt is very simple. So long as you're passing valid parameters, there is no way either function can fail. The problem is [u]very[/u] likely somewhere else.
Did you accidently change the LED pin to an input? That would explain why it doesn't turn on.
The LED pin is setup as an output.
I think the answer here is - No - attach/detach interrrupt is working as expected in Arduino 0018 (Duemillanove) and I don't recall any issues with prior versions either.
So the advice from Coding Badly to look eleswhere in your code makes sense.
Some things to try:
  • Increment a global volatile variable (one for each) whenever interrupts fire and print these in your loop for debugging whenver they change (seeing is believing).
  • Check that the code turning on the Led is indeed called and that pinMode is correct.
P.S. Currently, as a workaround I took out the detach and moved the attach to setup(). This isn't the best workaround because I use pulseIn() and the interrupt will mess with this.
After you call detachInterrupt, the interrupt will actually still fire - only the handler code you supplied will not be called. Just servicing the interrupt with the basic interrupt handler however carries overhead and may still upset the pulseIn function.
