attachInterrupt with an instance method
Is it possible to somehow invoke attachInterrupt from within a constructor and pass it a method of the instance?
I have found a thread with a similar problem but that's not quite what i'm looking for: Arduino Forum
I understand that it's not possible to invoke a member from within a static method and I understand that I can't pass an instance's method to attachInterrupt as my method (even I defined no parameters) has the invisible 'this' argument.
What I want is to have one instance of a class with a certain configuration (passed as constructor arguments). One part of the configuration is an interrupt pin.
I want to have a second instance of this class with a different interrupt pin.
I don't want the methods handling the interrupt to be in my setup/loop code, but in the .cpp where I implemented the class. I know that I could call attachInterrupt twice within setup() and have the two methods call something like myInstance.handleInterrupt(1), but if there's any chance to do it like I said before, it would prefer that way.
Is this possible?
The way described in the thread you linked to is the only I am aware of. You can do it a bit more clever and use some registration service to do the dispatching but you cannot use a method of an instance of a class as an interrupt handler.
You can do it like below with some static class members, but it's a bit fiddly:
class Foo
  static void isr0 ();
  static void isr1 ();
  const byte whichISR_;
  static Foo * instance0_;
  static Foo * instance1_;
  void handleInterrupt ();
  volatile int counter_;
  public:
    Foo (const byte which);
    void begin ();
};  // end of class Foo
void Foo::begin ()
  switch (whichISR_)
    case 0:
      attachInterrupt (0, isr0, FALLING);
      instance0_ = this;
    case 1:
      attachInterrupt (1, isr1, FALLING);
      instance1_ = this;
  }  // end of Foo::begin
// constructor
Foo::Foo (const byte whichISR) : whichISR_ (whichISR)
    counter_ = 0;
// ISR glue routines
void Foo::isr0 ()
  instance0_->handleInterrupt ();
  }  // end of Foo::isr0
void Foo::isr1 ()
  instance1_->handleInterrupt ();
  }  // end of Foo::isr1
// for use by ISR glue routines
Foo * Foo::instance0_;
Foo * Foo::instance1_;
// class instance to handle an interrupt
void Foo::handleInterrupt ()
  counter_++;
  // and whatever else
  }  // end of Foo::handleInterrupt
// instances of class
Foo firstFoo (0);
Foo secondFoo (1);
  firstFoo.begin ();
  secondFoo.begin ();
  }  // end of setup
void loop() { }
Thank you so much!
The code compiles now.
And after some very intense hours of looking at it and thinking, I even understand how it works :wink:
I've integrated it into my project and still compiles, but my Arduino seems crashing at some point (but that's beyond my initial question).
