attachInterrupt...
I've been trying to find a good description of what the first parameter in the attachInterrupt function is...can anyone help?
I've also seached these forums for information and found a confusing topic that throughout the code mentions two interrupts attached to pins 2 and 3 but I couldn't see anywhere in the source that defined this relationship.
I would like to use an interrupt on the rising edge of a push button.
Thank you
Interrupt zero is on pin 2, interrupt one is on pin 3
From the source (../hardware/arduino/core/arduino/WInterrupts.cpp)
void attachInterrupt(uint8_t interruptNum, void (*userFunc)(void), int mode) {
The interruptNum is 0 or 1 for standard Arduino (can go up to 5 on the Mega) and corresponds to INT0 and INT1 pins (which are same as digital pins 2 and 3 on the standard Arduino)
If you have a question like this remember you have all the source code, you can just have a look to see ;)
Ty, didn't realise I did, next time I will look, thanks again!
