attachInterruptParam method
Posting it here because couldn't find any documentation on it. It is available for Arduino Nano Every, the signature is this:
void attachInterruptParam(pin_size_t interruptNumber, voidFuncPtrParam callback, PinStatus mode, void *param);
Callback signature in this case:
void callbackFunc(void *param);
Useful if you want to call static member function then you can pass your class instance as param, for example:
class MyClass
	int pin;
	volatile int count;
public:
	static void HandleInterrupt(void* param)
		static_cast<MyClass*>(param)->count++;
	MyClass(int pin): pin(pin), count(0)
		attachInterruptParam(digitalPinToInterrupt(pin), &MyClass::HandleInterrupt, CHANGE, this);
	int GetCount()
		return count;
MyClass test1(PIN2);
MyClass test2(PIN7);
	Serial.println(test1.GetCount());
	Serial.println(test2.GetCount());
See here:
