Attachinterupt on Pin 2 move to Pin 20 on Mega
Hi All,
I am attempting to create a data logger that reports flow rate from a hall effect flow sensor to an online database using a GSM shield. I have gotten the flow sensor code to work and gotten the GSM code to work, but I have started to combine them and have run into the issue that both the GSM shield and the flow sensor need the interrupt function on pin 2. I went to go move the flow sensor to pin 20 on the mega, but now my flow sensor code won't even work.
If I plug the flow sensor into pin 2 and program the mega to read pin 20 for the flow sensor it works, but when I plug the flow sensor into pin 20 it does not work. The code I am using to read the flow sensor is attached.
Thanks so much for your help!
Ian
// reading liquid flow rate using Seeeduino and Water Flow Sensor from Seeedstudio.com
// Code adapted by Charles Gantt from PC Fan RPM code written by Crenn @thebestcasescenario.com
// http:/themakersworkbench.com http://thebestcasescenario.com http://seeedstudio.com
volatile int NbTopsFan; //measuring the rising edges of the signal
float Calc;
int hallsensor = 20;    //The pin location of the sensor
float d=0; //my summation variable
void rpm ()     //This is the function that the interupt calls
  NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
// The setup() method runs once, when the sketch starts
void setup() //
  pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
  Serial.begin(9600); //This is the setup function where the serial port is initialised,
  attachInterrupt(0, rpm, RISING); //and the interrupt is attached
// the loop() method runs over and over again,
// as long as the Arduino has power
void loop ()
  NbTopsFan = 0;   //Set NbTops to 0 ready for calculations
  sei();      //Enables interrupts
  delay (1000);   //Wait 1 second
  cli();      //Disable interrupts
  Calc = (NbTopsFan/(5.5*60)); //(Pulse frequency x 60) / 5.5Q, = flow rate in L/hour
  d=d+Calc;
  Serial.print ("Flow Rate[L/hr]:");
  Serial.print (Calc, DEC); //Prints the number calculated above
  Serial.print ("\r\n");
  Serial.print ("Total Flow[L]:");
  Serial.print (d, DEC); //Prints the number calculated above
Flow.ino (1.53 KB)
iangagnon:
See AttachInterrupt for the interrupt number of pin 20 of the mega.
hello,
How can I send the value of the flow using SMS.
I am having issues with using SMS and interrupt.
when I remove the interrupts then message is being sent, but the flow values can be calculated with interrupts only. is it so ?
how I can know the flow values without using interrupt ?
How to resolve the issue.
Thanks in advance.
