Hey all,
So I'm trying to use variables to set up my PubSubClient connection. When the port is hard coded, it seems fine but when I use a variable then it fails to connect:
Below shows the 2 methods I'm trying. The first one uses (int)mqtt_port and fails to connect. The second has it hard coded and works fine.
char mqtt_ip[16] = "192.168.1.82";
char mqtt_port[7] = "1883";
//This one doesn't work. When I try to connect I get message:
// Attempting MQTT connection... Failed.
PubSubClient client(mqtt_ip, (int)mqtt_port, callback, wifiClient);
//This one works fine
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
Can anyone tell me what's wrong here?
Thanks,
Cheese
Why are you trying to cast a constant string to an int ?
Have you tried printing (int)mqtt_port) ?
iow, how about char mqtt_port[7] = "1883\0";
and using atoi(mqqt_port) There must be a reason for wanting it as a c-string initially, i hope.
I await the reply with bated breath
No need for the explicit terminator as the compiler will add one anyway. Nor any need for the array size specifier either unless it is to be used to hold a longer string later
I'm never really sure about that, i know it does for a char *, and won't hurt might help.
Unless for some reason later in the code you need to know the actual length of the string
UKHeliBob:
I don't know about the OP, but I frequently reuse code for my Home IOT projects, and if I forget to make the pubSub client name unique, one or both fail to work.
Deva_Rishi:
iow, how about
and using
atoi(mqqt_port)
Thankyou. This did the job. There was no need to terminate it though.
As for the reason to use a c-string, I really can't tell you why. I think I got the code snippet from the WIFIManager GitHub for adding additional parameters. I'm no expert so I just followed that guidance. May or may not be right but it sure was a painful way to do it.
Thanks again.
char mqtt_ip[16] = "192.168.1.82";I sort of understand it for an IP address that you may want to show in the SM or on a page (i tend to keep a copy as a String as well) though there is a struct available called IPAddress theIP = IPAddress(192,168,4,1);
