Attempting to detect GSM call status
I am attempting to detect the status of a phone call; Ringing, Busy, Connected, etc. Once detected, I set a variable for future use. The below test code waits for an AT command to the GSM, then echo's the GSM response to the Monitor Serial. AT+CRSL=4 instructs the GSM module to echo the status in the form of "MO RING", "MO CONNECTED", etc.
I am fairly certain that the issue is in the statement ' if (receivedChars=="MO RING"){ '
From reading the forums it appears that I need to convert receivedChars to a string prior to doing the comparison.
Any Help would be appreciated!
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
int hit=0;
  Serial1.begin(115200);               // the GPRS baud rate
  Serial.begin(9600);                 // console baud rate
  Serial1.println("AT+CRSL=4");
  Serial.println("type AT command");
 if (Serial.available()){
    Serial1.write(Serial.read());
    delay(100);
 static byte ndx = 0;
 char endMarker = '\n';
 char rc;
 // if (Serial1.available() > 0) {
           while (Serial1.available() > 0 && newData == false) {
 rc = Serial1.read();
 if (rc != endMarker) {
 receivedChars[ndx] = rc;
 ndx++;
 if (ndx >= numChars) {
 ndx = numChars - 1;
 else {
 receivedChars[ndx] = '\0'; // terminate the string
 ndx = 0;
 newData = true;
 if (newData == true) {
 Serial.print("This just in ... ");
 Serial.println(receivedChars);
  Serial.println("HIT");  // just here for debugging
  hit=1;
 newData = false;
You cant do this:
char receivedChars[numChars];   // contains null terminated string
    // do something
You have to do something like this:
if (strcmp(receivedChars, "MO RING") == 0) {
    // do something
I really appreciate your effort to help. I made the below changes to the code:
  if (strcmp(receivedChars,"ATH") == 0) {
I get the below response from the serial monitor:
This just in ... ATH This just in ... OK This just in ...
I am expecting the word HIT to appear after "This just in ... ATH" inidcating a match. It appears that there may be something after the ATH. I have tried /n and /0 but still do not get the print of HIT indicating a match.
I am using ATH to simply for testing, that way I do not need to make a call to get the "MO RING", but I have tried with that also and there is not a match.
Thanks!
Just to check if you are getting extraneous characters in receivedChars which would interfere with your if statement, after:
You could do something like:
Serial.print(">") ;
Serial.print(rc) ;
Serial.println("<") ;
:) That helped... the ATH was getting ATH\r\r, and the MO RING\r, I made it difficult on myself by switching to ATH for my test as I did try the /r
Thanks for all of your help. this was the last stumbling block in my project of converting an old pay phone in to a pay cell phone. :)
Thanks for your assistance!
