Hello,
I have a light pattern working with the function Pattern_A_State(); but to use it for hundreds of different patterns would mean that I ned to repeat the switch case in each. I tried to make a modular function but cannot get it to work.
Any suggestions appreciated.
Thank you.
#include <ShiftRegister74HC595.h>
unsigned long currentMillis = 1;
const byte lightPins[] = {99, A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15, 1, 2, 3, 4, 5, 6, 7, 8};
// 99 not used but hack to avoid unfilled array groups returning 0 and lighting first pin
byte numberOfShiftRegisters = 3; // number of shift registers attached in series
byte serialDataPin = 51; // blue wire
byte clockPin = 52; // yellow wire
byte latchPin = 53; // green wire
#define ArrayCount(array) (sizeof array / sizeof array[0])
ShiftRegister74HC595 sr (numberOfShiftRegisters, serialDataPin, clockPin, latchPin);
int state = 1; // anyway to not have these be global variables?
int i = 0; // stat and i? // It would be great to either pass them in the function call or have them declared in the switch case block
unsigned long previousLed_A_Millis = millis(); // needs to be kept track of for each simultaneous light pattern but can it be not be global so I don't need a seperate counter for each pattern?
const byte numberOfLights = 49; // number of light strings 48 in testing 96 in production
byte numberOfArduinoPins = 25; // 24 in testing 66 in production
byte numberOfShiftRegisterPins = 25; // 24 in testing 30 in production
void setup () {
//Set each pin connected to light string to output mode
for (byte i = 0; i <= numberOfArduinoPins; i++)
pinMode(lightPins[i], OUTPUT);
// Prevent relays from starting up engaged
digitalWrite(lightPins[i], LOW);
// Prevent shift register controled relays from starting up engaged
for (byte i = 0; i <= numberOfShiftRegisterPins; i++)
sr.set(i, HIGH); // HIGH in testing rig relays but LOW in production
// randomSeed(analogRead(0)); // gets a random analog read each time sketch runs
currentMillis = millis();
Pattern_A_State(200, 400);
//pattern1Call();
void Pattern_A_State(int interval1, int interval2)
int lightGroups[6][20] = { {20, 21, 28, 29} , {11, 12, 13, 14, 22, 30, 38, 37, 36, 35, 27, 19} , {2, 3, 4, 5, 6, 7, 15, 23, 31, 39, 47, 46, 45, 44, 43, 42, 34, 26, 18, 10} , {1, 9, 17, 25, 33, 41, 8, 16, 24, 32, 40, 48} , {2, 3, 4, 5, 6, 7, 15, 23, 31, 39, 47, 46, 45, 44, 43, 42, 34, 26, 18, 10} , {11, 12, 13, 14, 22, 30, 38, 37, 36, 35, 27, 19} };
/// seams inefficient to repeat everything below for eacht pattern. Is there a way to make the below a function and pass each different lightGroups to it?
int numRows = ArrayCount(lightGroups);
int numColumns = ArrayCount(lightGroups[i]);
switch ( state )
case 1:
for (int j = 0; j < numColumns; j++) {
lightcontrolon(lightGroups[i][j]);
if (currentMillis - previousLed_A_Millis >= interval1)
previousLed_A_Millis = currentMillis;
state = 2;
case 2:
lightcontroloff(lightGroups[i][j]);
if (currentMillis - previousLed_A_Millis >= interval2)
previousLed_A_Millis = + currentMillis;
i++;
if (i >= numRows) {
i = 0;
state = 1;
void makeReusableFunctionAttempt (int interval1, int interval2, int lightGroups[6][20], unsigned long previousLed_A_Millis )
switch ( state )
case 1:
state = 2;
case 2:
i++;
if (i >= numRows) {
i = 0;
state = 1;
void pattern1Call()
makeReusableFunctionAttempt(200, 400, lightGroups[6][20], 30);
// turns lights on by pin and turns shift registers on by pin if greater than number of light pins
void lightcontrolon(byte lightno) {
if (lightno < (numberOfArduinoPins + 1)) {
digitalWrite(lightPins[lightno], HIGH); // HIGH trigger relays
byte shiftno = lightno - numberOfArduinoPins;
sr.set(shiftno, LOW); // LOW in testing rig relays but HIGH in production
// turns lights off by pin and turns shift registers off by pin if greater than number of light pins
void lightcontroloff(byte lightno) {
digitalWrite(lightPins[lightno], LOW); // HIGH trigger relays
sr.set(shiftno, HIGH); // HIGH in testing rig relays but LOW in production
