Hello all
I'm attempting to move a group of 3 pixels down an LED strip. I can successfully send 1 down and continue repeating. However, when changing [i] to [i + 3], I thought I would see 3 pixels traveling down. But not working correctly. Any ideas?
// Use if you want to force the software SPI subsystem to be used for some reason (generally, you don't)
// #define FASTLED_FORCE_SOFTWARE_SPI
// Use if you want to force non-accelerated pin access (hint: you really don't, it breaks lots of things)
// #define FASTLED_FORCE_SOFTWARE_PINS
#include <FastLED.h>
// Move a white dot along the strip of leds. This program simply shows how to configure the leds,
// and then how to turn a single pixel white and then off, moving down the line of pixels.
#define NUM_LEDS 70
#define DATA_PIN 5
//#define CLOCK_PIN 13
// This is an array of leds. One item for each led in your strip.
CRGB leds[NUM_LEDS];
// This function sets up the leds and tells the controller about them
// sanity check delay - allows reprogramming if accidently blowing power w/leds
delay(2000);
FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
fill_solid(leds, NUM_LEDS, CRGB::Red);
// This function runs over and over, and is where you do the magic to light
// your leds.
for(int i = NUM_LEDS-1; i >= 0; i--) {
// Turn our current led on to white, then show the leds
leds[i+3] = CRGB::Red;
// Show the leds (only one of which is set to white, from above)
FastLED.show();
// Wait a little bit
delay(20);
// Turn our current led back to black for the next loop around
leds[i] = CRGB::White;
