Attempting to run WebServer and getting error
I just bought a “LinkSprite CuHead WiFi Shield for Arduino” from CuteDigi. I am attempting to test it as described in the wiki page http://asynclabs.com/wiki/index.php?title=AsyncLabsWiki. I downloaded the library and installed it as directed and pulled in the WebServer example. It compiles just fine, but after downloading to the Arduino I get the error message:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
The only modifications I have made to the sketch is entering my SSID and passwords. My Arduino is a Duemilanove. Anyone, any ideas?
Jim
When this error message is printed, it is accompanied by a link to the Troubleshooting section. What steps have you tried there? With what results?
Typical errors are not selecting the right board and/or the right port, in the Tools menu.
The code does not get loaded on the shield. Are you able to upload code to the Arduino without the shield attached?
PaulS: When this error message is printed, it is accompanied by a link to the Troubleshooting section. What steps have you tried there? With what results?
These are the error messages exactly as received(copied from the information line). I loaded a test sketch to the board and it ran perfectly(blinking led).
Jim
When I get this kind of avrdude errors I always check if I selected the right board and comport under the tools menu. If OK then I disconnect the Arduino for 5 seconds so the OS can refresh its internal administration..
robtillaart: When I get this kind of avrdude errors I always check if I selected the right board and comport under the tools menu. If OK then I disconnect the Arduino for 5 seconds so the OS can refresh its internal administration..
I'm in the house right now, I try this when I go back to my observatory. Thanks!
Jim
Of all the things you would never suspect, I had a bad USB cable.
Jim
