I feel I should know how to do this but my mind is a bit cloudy...
I have a 0-24V square wave that I need to condition into a 0-5V signal for the Arduino. I didn't want to use a voltage regulator or a normal op amp to do it because I'm concerned about the 0V. Many amps and amp-based ICs can't actually hit 0V and while that may not prevent the Arduino from registering a low, I want to play things safe and get a real 0V when the input is 0 and also I don't want to chop the signal but rather attenuate it. I have a feeling I'm going to need to know how to do that anyway in case I need to similarly condition an analog signal.
An amplifier with a split supply should in theory have no problem with 0 or 5V right? Thing is, both my supply and my incoming signal are 24V high so I'd need a small arduino board (for convenience) with an amp on it that's split supply AND can cover this range AND maybe also has the onboard IC to turn a single ended supply into a double-ended one. They have those... what do you call them... split capacitor supply chips or something like that where they use some tuned circuit to turn +V into +/-V ?
Anyway this is 1 thought and probably doesn't exist in a single package but there is probably another way to do what I'm trying to do that isn't so complicated. Just wondering what the conventional wisdom is on the topic?
I would just think about using a common opto-coupler. That also gets you isolation. Roll your own or just buy an off the shelf unit module. They cost about $6.00 USD to $10 USD on Amazon for a 4 channel module. They are popular in PLC applications.
If you are sure the voltage never goes over 24V you can use a [u]voltage divider[/u] (2 resistors).
Or, since it's a square wave (digital) and you don't need to measure/sense anything between zero and 24V you can use an [u]over-voltage protection circuit[/u]. Or, you can add a "protection diode" to a voltage divider. (If you build the protection circuit, I'd recommend increasing the current limiting resistor to 1K or more.)
Well, the voltage should be stable as it's coming from a sensor via a DC supply. Oddly the resistive network seems like the best solution even though I'd stay away from that normally because of potential loading issues. But the circuit has nothing in it but a sensor and an arduino so I guess the risk is minimal. It would be nice to know a single ended supply type amplifier though which can tolerate voltages close to 0. That would offer the benefit of isolation at least.
I'm convinced that you are over-complicating it, but if you want to go that route, you can use something like an LM397 comparator. There would still be a voltage divider of some sort, but the impedance would be much higher if you are worried about loading.
Really, I would need many more details about your circuit to give a good answer. As always.
If you want to MEASURE the voltages, you can just use a divider chain to an analog input. If you want to COUNT or TIME the pulses, then you can use an optocoupler as suggested, or more simply a suitable current limiting resistor with diodes to prevent the input going outside the supply rails.
Gahhhrrrlic:
You don't need an amplifier to attenuate, unless the source is very high impedance (mega-ohms).
Furthermore an amplifier powered from 24V will not be safe to connect to an Arduino pin any more
than its input signal. On powerup/powerdown such an amp may produce transient spikes upto the
supply voltage.
Normally a voltage divider, or voltage clamp (resistor + zener) would be employed to translate a signal
from 24V to 5V.
A regulator would never be appropriate for reducing a signal voltage, and a resistor divider would not be
appropriate to reduce power voltage - signals and power are done differently.
