attiny 2313 and the IRremote.h library
hello i’ve tried to upload this code to an attiny2313 @8mhz internal clock.
#include <IRremote.h>
const int pin=3;
const int led=9;
int toggle=0;
IRrecv irrecv(pin);
decode_results results;
irrecv.enableIRIn();
pinMode(led,OUTPUT);
if(irrecv.decode(&results)){
if(results.value==0x1000C||0xC||0x17AB7F3E){
if(toggle==0){
digitalWrite(led,HIGH);
toggle=1;
else{
digitalWrite(led,LOW);
toggle=0;
irrecv.resume();
pretty simple really, just trying something.
it will give me a lot of errors in the verbose, they’re so many that i think is rude to post them all, but i can do if needed. but the errors look mostly like this.
G:\arduino\libraries\IRremote\boarddefs.h:217:29: error: ‘WGM22’ was not declared in this scope
TCCR2B = _BV(WGM22) | _BV(CS20); \
G:\arduino\libraries\IRremote\irSend.cpp:119:2: note: in expansion of macro ‘TIMER_CONFIG_KHZ’
TIMER_CONFIG_KHZ(khz);
G:\arduino\libraries\IRremote\boarddefs.h:217:42: error: ‘CS20’ was not declared in this scope
In file included from G:\arduino\libraries\IRremote\IRremoteInt.h:111:0,
from G:\arduino\libraries\IRremote\IRremote.h:24,
from G:\arduino\libraries\IRremote\irSend.cpp:1:
G:\arduino\libraries\IRremote\boarddefs.h:218:2: error: ‘OCR2A’ was not declared in this scope
OCR2A = pwmval; \
G:\arduino\libraries\IRremote\boarddefs.h:219:2: error: ‘OCR2B’ was not declared in this scope
OCR2B = pwmval / 3; \
i have the feeling that the attiny is not compatible with the library.
That would be correct.
To boarddefs.h, change:
#elif defined(__AVR_ATtiny84__)
    #define IR_USE_TIMER1     // tx = pin 6
to
#elif defined(__AVR_ATtiny84__)||defined(__AVR_ATtiny2313__)||defined(__AVR_ATtiny4313__)
and it should work, assuming it fits in 2k of flash, which it might not.
