Attiny 4313
If you want to use the Attiny4313 instead of the Attiny2313 add following lines to …/arduino/hardware/board.txt
No further changes required. Check fuses and other settings if you want to change cpu speed. I make my test with 4 MHz only.
attiny4313-8.name=ATtiny4313 (@ 4Mhz)
#attiny4313-8.upload.using=arduino:arduinoisp
attiny4313-8.upload.maximum_size=4096
attiny4313-8.bootloader.low_fuses=0xE4
attiny4313-8.bootloader.high_fuses=0x9F
attiny4313-8.bootloader.extended_fuses=0xFF
attiny4313-8.build.mcu=attiny2313
attiny4313-8.build.f_cpu=4000000UL
attiny4313-8.build.core=arduino:arduino
attiny4313-8.build.variant=tiny2313
attiny4313-8.build.signature= 0x1e 0x91 0x0D;
