Attiny 45/85 on arduino, will intterrupt work?
i was reading on this site http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585
on how to work attiny 45/85 with arduino board,
so my question is, will interrupt work as atmel328 do?
seems like...
seen the datasheet: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ATTINY45-20PI-ND ?
-arne
yes but does arduino support it?
oh - hum...
since millis() works, interrupts will work, 2...
maybe some register addresses r different... my arduino IDE doesnt know the attiny45... does urs?
-arne
Here it shows how can arduino read it http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585
oh - i c - the IDE can be upgraded... cool! 8-)
so can anyone help me on how can i make interupt work?
could u specify what doesnt work?
according to ur URL millis() will work... so interrupts work...
or not?
-arne
i tried interrupt and it doesnt work
how did u try it? -arne
attachInterrupt(1, blink, CHANGE); and attachInterrupt(0, blink, CHANGE);
but it seems it can't understand witch one is 1 or 0 interrupt
any idea please?
did u test if millis() works? -arne
nop, why?
why dont u do that first:
void setup() { pinMode(2,OUTPUT); }
  digitalWrite(2,HIGH);
  delay(100);
  digitalWrite(2,LOW);
  delay(2000);
(with a led in series with 10kR at digital pin 2)?
my idea is: if delay+millis dont work, then ur URL is wrong... if they do work, then ur sketch is wrong...
-arne
i tried this and it doesnt works
int led_pin =4;
volatile int state = LOW;
  pinMode(led_pin, OUTPUT);
  digitalWrite(led_pin,state);
void blink()
  state = !state;
any other code (digitaWrite,analogRead,delay...) works
What is feeding into pin2 that is generating the interrupt? Does the attiny 45/85 use the same input pin for the interrupt that attachInterrupt is supposed to be watching for?
pin2 on attiny 45 is INT2,
so when i call attachInterrupt(0, blink, CHANGE); i call pin2 right? why i have the problem?
can u find out what the content of the interrupt registers is (before and after the attachInt...() call)?
e. g. MCUCR, GIMSK, PCMSK, ...
maybe u could do it with a flash code? 1: long on, then short off 0: short on, then short off after 8 bits: long off
or does serial work?
-arne
i really dont understand what you mean, i only know some things on arduino
