Attiny 84 is programmed but it is not working
Hello,
i am working with Attiny 84, i have programmed 6 microcontroller, two of them are working and th rest are not wotking.
i have tried so much but they are not working even they programmed.
could some one help me please
Please provide a detailed explanation of what you mean by "not working".
i mean when i uploaded the program everzthing was ok, there was no problem but afterthat some of them working perfectly and the rest are not giving signals
thanks in advance
Did you flash the fuses first before use ?
Also known as burning the bootloader on ATTINY.
Doesn't usually burn a proper bootloader but simple does a FUSE setting ready for future use.
Bob.
Something is different between these 6 specimens. Either you uploaded different code or forgot burn bootloader to set fuses on the non-working ones, or there are bad connections in the hardware of the non-working ones.
