I am using the attached code which is the mix of the
- Example SRF (Sonic Range Finder) http://arduino.cc/en/Tutorial/SFRRangerReader
- Example of the 7 Segment IC Shift register 74HC595 found at instructables : http://www.instructables.com/id/Temperature-Displayed-on-4-Digit-7-segment-common/
I have verified it with the UNO and everything worked perfect.
Now I wanted to go to the Attiny 84 and verified beforehand the BLINKING and FADING examples to work perfectly (so Bootloader worked), but then I got errors regarding the SFR section where the Wire.h was not recognized.
Any idea how I could use the Attiny with the Devantech SFR02?
btw: the IDE I am using is 1.0.4.
Many thanks in advance
Y3G
attiny84.txt (4.05 KB)
