attiny 85 correct calling of pins ?
the code below was working fine on my mega using pins A0 and 40 and 50 on off
im just reading a pot value of a joy stick and spliting it in to 2 derctions useing relays hooked to 40 and 50 on the old porgram for the mega
now ive made some changes to the code and uploaded to to an attiny85
now i need a pin for my pot pin from the joy stick
and another for my bacwards / forwards toggle relay
and the last pin to cut power when the joy stick pot reads between 450 and 500
so i changed the int pin for A0 to 2;
and my toggle deriction to 1 ;
and relay to cut power to 0;
not working quite the way i pland on the attiny 85
think im just confused on what pins do what and how the are called out in the program for the at85 ?
first old code then what i up loaded to the attiny 85
next the revsied code for the attiny 85
// These constants won't change:
const int analogPin = A0;
const int derictPin = A0;
// pin that the sensor is attached to
const int ledPin = 50;       // pin that the LED is attached to has derction of dc motor relay
const int threshold = 600;   // an arbitrary threshold level that's in the range of the analog input
int toggle = 40; // motor  on / off
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(toggle, OUTPUT);
  // initialize serial communications:
  // read the value of the potentiometer:
  int analogValue = analogRead(analogPin);
  // if the analog value is high enough, turn on the LED:
  if (analogValue < 405) {
     Serial.println(analogValue);
     analogRead(derictPin);
      Serial.println(derictPin);
    int analogValue = analogRead(A0);
    analogValue = map(analogRead(A0), 440, 0, 255, 0);
    digitalWrite(ledPin, HIGH);
    analogWrite(12,analogValue/4-60);
    digitalWrite(toggle, HIGH);
    delay(30);
  else if (analogValue > 505)
    analogValue = map(analogRead(A0), 450, 1023, 255, 0);
    digitalWrite(ledPin,LOW); // led pin toggles revers polarity of dc motor relay for now
    delay(30);
    analogValue = map(analogRead(A0), 431, 449, -1, 1);
      digitalWrite(toggle,LOW);
    // print the analog value:
    delay(30);
const int analogPin = 2;
const int derictPin = 2;
const int ledPin = 0;       // pin that the LED is attached to has derction of dc motor relay
int toggle = 1; // motor  on / off
    int analogValue = analogRead(2);
    analogValue = map(analogRead(2), 440, 0, 255, 0);
    delay(30);
    analogValue = map(analogRead(2), 450, 1023, 255, 0);
    delay(30);
    analogValue = map(analogRead(2), 431, 449, -1, 1);
    delay(30);
Pin names for non-Arduino cores will depend on which core you use.
If you use the High-Low Tech core from MIT you can find the pin diagram here:
http://hlt.media.mit.edu/?p=1695
awsome the link i found dident work thanks !!
