ATtiny 85 soil helper.
Hi so I programmed my ATtiny85 with the following code to show me when I need to water my plant but it doesn’t work. Could anybody please help me out here?
Thanks in advance!
const int VAL_PROBE = 7; // Analog pin 0
const int MOISTURE_LEVEL = 0; // the value after the LED goes ON
void Dry(int state) {
    digitalWrite(5, state);
//Also, at which point is it in the water, the high numbers (like 1022) or the lower numbers?
void Humid(int state) {
    digitalWrite(6, state);
void Water(int state) {
    digitalWrite(3, state);
    int moisture = analogRead(VAL_PROBE);
    if(moisture >= 170) {
        Dry(HIGH);
    } else   {
        Dry(LOW);
    if(moisture>=70 && moisture<170) {
        Humid(HIGH);
    } else   {
        Humid(LOW);
    if(moisture <70) {
        Water(HIGH);
    } else   {
        Water(LOW);
(deleted)
