Attiny Custom Library Error
Hello, I am experiencing a recurring issue that I can't find any posts that provide a solution. I have code that includes a custom cpp Library I created. When I run my code on Arduino, things run fine. But when I go to upload it to the ATtiny 85 I get the following error. Any help would be appreciated. Its driving me nuts. I have included library file and header file.
libraries\LEDController\LEDPattern.cpp.o: In function `Pattern::Pattern(double*, double*, int)':
C:\Users\Jeff\Documents\Arduino\libraries\LEDController/LEDPattern.cpp:21: undefined reference to `operator new[](unsigned int)'
libraries\LEDController\LEDPattern.cpp.o: In function `LEDProgram::LEDProgram(Pattern*, int)':
C:\Users\Jeff\Documents\Arduino\libraries\LEDController/LEDPattern.cpp:35: undefined reference to `operator new[](unsigned int)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board ATtiny85 @ 8 MHz (internal oscillator; BOD disabled).
LEDPattern.cpp (1.7 KB)
LEDPattern.h (940 Bytes)
I think that new() should not be used at all on an ATtiny with small RAM.
I did a deep dive and it seemed in needed to include the 'new.h' and 'new.cpp' files that allow for using the operator 'new'.
So now the program compiles without any errors. However it still does not operate as it does when it is run through an Arduino. I think there is some other aspect of creating objects that is not the same on Attiny as Arduino. I will keep searching.
