ATtiny Low Power Watch
Hi, I am trying to make a low-power watch with an attiny microcontroller.
First of all, is there a way to get accurate timing on an attiny without using an rtc? I have read you can use a 32kHz watch crystal, is that true?
Also, would there be a way to limit power consumption when not in use while still keeping time? I have heard of a "watchdog timer". Could someone explain that to me?
Thanks
You can certainly use a 32 kHz crystal, which will give you timing as accurate as any wristwatch, but don't expect to do much computing or even use the Arduino system.
This is not a simple project, so be prepared for a long course of study. Pick one of the many ATTinys and study the data sheet carefully, paying close attention to sleep modes, timers and power saving techniques.
You will need an Atmel development system, such as Studio 4 or 7, and an ISP programmer.
I am willing to do the studying. However, my experience with programming attiny chips is limited to using an uno as an ISP :P
Can you point me in the right directions (in other words links)? Keep in mind I'm a beginner.
Also, is there a better/easier way of doing this? Would an ATmega be better?
An ATMega328 would be easier and lots of people have made wristwatches with them. Google will find them.
You can use a watch crystal and Timer2 to create an RTC, however you will have to configure the ATMega to use the internal 8 MHz RC oscillator for everything else. Here is some code I used for a solar powered data logger that works on this principle.
// ATmega328p Solar/SuperCap powered Real Time Clock and voltage monitor.
// VirtualWire data  transmission
// power reduction techniques from http://www.gammon.com.au/power
// This code incorporates an RTC formed by Timer2 and a 32768 xtal on OSC pins
// The internal 8MHz RC oscillator is calibrated by comparison with the 32768 Hz standard
// Mini-uino board from http://crossroadsfencing.com/BobuinoRev17/index.html
// fuses: 8 MHz internal RC clock, LP xtal (32768 Hz) on OSC pins
//  Binary BCD HH:MM:SS time version, RTC maintained in global array RTC_buf[]
//  Data output on PORTD,1 (VirtualWire TX)
//  Power output on PORTD,2 (TX module)
#include <avr/sleep.h>
#include <avr/power.h>
#include <util/delay.h>
#include <VirtualWire.h>
/ Global variables for RTC, time and day
// set the time here, if you like
  volatile unsigned char RTC_buf[]={0,0,0,0,0,0}; //binary BCD hh:mm:ss (24 hour clock)
  volatile unsigned int dayno=0; //days since startup
  char buf[40]; //sprintf buffer, about 30 chars actually used
  int VW_PWR=2;    //433 MHz TX power
  int VW_TX=3;     //Virtual Wire TX
** approximate 1ms delays (can't use Arduino delay - timer disabled)
void delay1ms(unsigned int ms)
  while (ms--) _delay_ms(1);
// everything happens in setup()
  char t,zero=0;
  unsigned int batt,h,m,s;
  pinMode(VW_PWR,OUTPUT);  //transmitter power
  digitalWrite(VW_PWR,LOW); // TX off
  pinMode(VW_TX,OUTPUT);
  digitalWrite(VW_TX,LOW);
  //PRR Power Reduction Register (set PRADC after ADCSRA=0)
  //Bit 7 - PRTWI: Power Reduction TWI
  //Bit 6 - PRTIM2: Power Reduction Timer/Counter2
  //Bit 5 - PRTIM0: Power Reduction Timer/Counter0
  //Bit 3 - PRTIM1: Power Reduction Timer/Counter1
  //Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
  //Bit 1 - PRUSART0: Power Reduction USART0
  //Bit 0 - PRADC: Power Reduction ADC
  ADCSRA = 0; //disable ADC
  PRR |= (1<<PRTWI)|(1<<PRSPI)|(1<<PRTIM0)|(1<<PRUSART0)|(1<<PRADC); //need Timers 1 and 2
  OSCCAL_calibrate();  //calibrate the RC osc for accurate timing using the 32 kHz crystal
  timer2_init(); //setup timer2 interrupts for RTC
  vw_set_tx_pin(VW_TX);  //initialize VirtualWire TX
  vw_setup(2000); // and bits per sec
  sei();  //enable interrupts
  t=255; //initialize loop timer
  while(1) {
    // wake up on Timer2 overflow (1/sec)
    // output day, time and cpu voltage on uart every 10 minutes
    if(t != RTC_buf[3]) {
      t=RTC_buf[3];
      s=10*RTC_buf[4]+RTC_buf[5]; //format time (seconds)
      m=10*RTC_buf[2]+RTC_buf[3]; //minutes
      h=10*RTC_buf[0]+RTC_buf[1]; //hours
      digitalWrite(VW_PWR,HIGH);  //power on TX
      PRR &= ~(1<<PRADC); //turn ADC back on
      ADCSRA = (1<<ADEN);  //enable and
      ADCSRA |= (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2);  // set prescaler to 128
      delay1ms(10); //let ADC and TX stabilize
      batt = readVcc(); //get Vcc voltage
      // format days, time and battery voltage
      sprintf(buf,"%0u,%0d,%0d,%0d,%0u%c",dayno,h,m,s,batt,zero); //max ~16 characters
      vw_send((uint8_t *)buf, strlen(buf)); //send it
      vw_wait_tx(); // Wait until message is sent
      digitalWrite(VW_TX,LOW); //power off TX
      ADCSRA = 0; //ADC off
      PRR |= (1<<PRADC);
    } //end if (t)
    //go back to sleep
    set_sleep_mode(SLEEP_MODE_PWR_SAVE);
    sleep_enable();
    cli(); //time critical steps follow
    MCUCR = (1<<BODS) | (1<<BODSE); // turn on brown-out enable select
    MCUCR = (1<<BODS);         //Brown out off. This must be done within 4 clock cycles of above
    sei();
    sleep_cpu();
  } //end while(1)
}  //do everything in setup()
//  Timer2 Interrupt Service
//  32 kKz / 256 = 1 Hz with prescaler 128
//  provides binary BCD Real Time Clock
//  no check for illegal values of RTC_buffer upon startup!
ISR (TIMER2_OVF_vect) {
  // RTC function
  RTC_buf[5]++; // increment second
  if (RTC_buf[5] > 9)
    RTC_buf[5]=0; // increment ten seconds
    RTC_buf[4]++;
    if ( RTC_buf[4] > 5)
      RTC_buf[4]=0;
      RTC_buf[3]++; // increment minutes
      if (RTC_buf[3] > 9)
        RTC_buf[3]=0;
        RTC_buf[2]++; // increment ten minutes
        if (RTC_buf[2] > 5)
          RTC_buf[2]=0;
          RTC_buf[1]++; // increment hours
          char b = RTC_buf[0]; // tens of hours, handle rollover at 19 or 23
          if ( ((b < 2) && (RTC_buf[1] > 9)) || ((b==2) && (RTC_buf[1] > 3)) )
            RTC_buf[1]=0;
            RTC_buf[0]++; // increment ten hours and day number, if midnight rollover
            if (RTC_buf[0] > 2) {
              RTC_buf[0]=0;
              dayno++; //one day at a time...
// initialize Timer2 as asynchronous 32768 Hz timing source
void timer2_init(void) {
  TCCR2B = 0;  //stop Timer 2
  TIMSK2 = 0; // disable Timer 2 interrupts
  ASSR = (1<<AS2); // select asynchronous operation of Timer2
  TCNT2 = 0; // clear Timer 2 counter
  TCCR2A = 0; //normal count up mode, no port output
  TCCR2B = (1<<CS22) | (1<<CS20); // select prescaler 128 => 1 sec between each overflow
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB))); // wait for TCN2UB and TCR2BUB to clear
  TIFR2 = 0xFF; // clear all interrupt flags
  TIMSK2 = (1<<TOIE2); // enable Timer2 overflow interrupt
// Read 1.1V reference against AVcc
// return battery voltage in millivolts
// must be individually calibrated for each CPU
unsigned int readVcc(void) {
  unsigned int result;
  // set the reference to Vcc and the measurement to the internal 1.1V reference
  ADMUX = (1<<REFS0) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1);
  delay1ms(2); // Wait for Vref to settle
  ADCSRA |= (1<<ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // wait until done
  result = ADC;
  // second time is a charm
  result = ADC;
  // calibrated for my Miniduino
  result = 1195700UL / (unsigned long)result; //1126400 = 1.1*1024*1000
  return result; // Vcc in millivolts
// Calibrate the internal OSCCAL byte, using the external 32768 Hz crystal as reference.
void OSCCAL_calibrate(void)  //This version specific to ATmegaXX8
  unsigned char calibrate = 0; //not calibrated;
  unsigned int temp;
  TIMSK1 = 0; //disable Timer1,2 interrupts
  TIMSK2 = 0;
  ASSR = (1<<AS2);        //select asynchronous operation of timer2 (32,768kHz)
  OCR2A = 200;            // set timer2 compare value
  TCCR1A = 0;
  TCCR1B = (1<<CS11);     // start timer1 with prescaler 8
  TCCR2B = (1<<CS20);     // start timer2 with no prescaling (ATmega169 use TCCR2A!)
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB)));  //wait for TCN2UB and TCR2BUB to be cleared
  delay1ms(2000); //allow xtal osc to stabilize
  while(!calibrate)
    cli(); // disable global interrupt
    TIFR1 = 0xFF;   // clear Timer1 flags
    TIFR2 = 0xFF;   // clear Timer2 flags
    TCNT1 = 0;      // clear timer1 counter
    TCNT2 = 0;      // clear timer2 counter
    TCCR1B = (1<<CS11); // start timer1 (again)
    while ( !(TIFR2&(1<<OCF2A)) );   // wait for timer2 compareflag
    TCCR1B = 0; // stop timer1
    sei(); // reenable global interrupts
    if ( TIFR1&(1<<TOV1) ) temp = 0xFFFF;   //overflow, load max
    else   temp = TCNT1;
   //expect about (1e6/32768)*201 = 6134 ticks
    if ( (temp >= 6125) && (temp <= 6145) ) calibrate=1;
    if (temp > 6145) OSCCAL--;   //RC oscillator runs too fast, decrease OSCCAL
    if (temp < 6125) OSCCAL++;   //RC oscillator runs too slow, increase OSCCAL
  } //end while(!calibrate)
} //return
Okay, then I'll go for the ATmega.
What is the best way to program one? From what I've read you use FTDI, right? As for software, do I still use the Arduino IDE or something else?
Hiya GecloDiode (interesting name dude),
I have used a tiny85 for a clock, and they work nicely without an external rtc if you take the time to calibrate them. Here's a clock (for a littleBits project) that holds to +/- 3 seconds a day (using a ceramic resonator no less.)
|500x333
ps, unlike jremington, I am a lightweight, and programmed my tiny85 with the IDE and a Sparkfun Pocket Programmer
Looks good, Chris! How is the time displayed?
There's a timepiece collaboration in Gigs and Collaborations:
http://forum.arduino.cc/index.php?topic=369599.0
Wow, looks cool. I see two IC's (pun), what's the second?
I definitely will check out the Pocket Programmer (thanks for the tip).
However, I'm not sure whether to use an ATtiny or an ATmega now. Any thoughts?
My main constraints are power (must function on 2-3V), size (less components and SMD chips are best), and simplicity (although I can learn quickly I am still a beginner so any links/tuts are very welcome).
jremington: Looks good, Chris! How is the time displayed?
Thanks jremington!
I built this to be part of the littleBits system, which is highly modular. The output from this module is a voltage corresponding to the time (196mV/hr, which resets at midnight.) The other modules use that voltage to show the time, or do something which is time based. I have it on a globe which is turned by a stepper motor. Once a day, it signals the globe to turn to a reference position, and so the globe is always in the same position, relative to the "sun" as the actual Earth.
GeckoDiode: Wow, looks cool. I see two IC's (pun), what's the second?
Thanks! The smaller chip is a tiny 85, the larger one is a quad op-amp (A Burr Brown OPA4243 from a decade or so ago.) In this piece's current form, it also has a couple BIG capacitors on it: A 1000uf to condition the power, and a 1F to keep it running in case of an accidental disconnect. LittleBits holds circuits together with magnets, and if you move them around, there is the danger of them coming apart. Since it needs to be manually reset if it's turned off, I wanted to minimize that happening.
I've used both, and generally I let the pins decide. A tiny 85 has only a few pins (3 if you add an external oscillator), so it's pretty limited. I also use the tiny 84. I haven't discovered how to use I2C with the '84, and I'm into I2C now, so I don't use it as much (although I built a rocking clock with one - I wedged a thermistor between the crystal and the chip to control the time rate according to temperature. A diy TCO!
Although I have a couple of ATMega 328p chips, I never feel like using them, because little boards like the trinket pro, the beetle, and even the Arduino Micro are just so convenient! If I need a bunch of pins for a project, I usually use one of those. Since you are considering making a watch, size would seem to be important. But so is function, so there's your tradeoff.
