attiny randomizer help
hey, I have been fiddling with this randomizing function... it works for my arduino, but when I uploaded it to an attiny85, both pins lit up at the same time.... not sure why this is.
explanation?
//Randomizer
int LED_2 = 2; int LED_3 = 3;
// a variable to hold a random number long randomNumber;
pinMode(LED_2, OUTPUT); pinMode(LED_3, OUTPUT);
// generate a random seed or starting number randomSeed( analogRead(0) );
void loop() { // assign a random number to our variable
randomNumber = random (2,4);
digitalWrite(randomNumber, HIGH);
delay(100);
digitalWrite(randomNumber, LOW);
Try analogRead(1)
Code posted properly, using code tags, with excess blank lines removed. No need to use a long integer to reference a pin number.
Keep in mind that the LEDs may be OFF for only a few microseconds, in which case you will not see them unlit.
Do you have the required current limiting resistors in series with the LEDs?
// Randomizer
int LED_2 = 2;
int LED_3 = 3;
byte randomNumber;
  randomNumber = random (2, 4);
  delay(100);
yes.
update:
I tried uploading to a different attiny85 just for kicks to see if it changed anything and it seems like the first one was defective. i’m not sure what the problem was.
