I hate messy jumper leads so here's a shield i made to get rid of them, It just needs a 20pin DIL socket and it's done, the jumper selects either 8pin or 20pin chips, the plan is to use it to program some attiny13a's I have, 20 pins will be for attiny2313's
Before anyone ask's MollyMitens is a cat I lost a few years ago, all my homebrew pcb's carry the name of former pets so they will live on, that's just how I am
Thanks, Im not so hot on Atmel hardware yet, which 14 pin chips did you have in mind, so long as they have the same ICSP pinout they would drop into the 20 pin socket the only difference would be where gnd is situated, I chose 8 & 20 pin as thats what i intend to use.
In the next revision i intend to get rid of the ground select jumper and use a digital pin set to LOW to act as a virtual ground, it works with led's so it should work with uC's
attiny84, one of my favorites
Is the capacitor to disable auto-reset?
Yes to the capacitor,
I see the 84's have an altogether different pinout to 13a & 2313, there would be enough space to add a 14 pin socket
