ATtiny that's arduino compatable with 3x independent PWM channels
Using parametric search on Atmel site I'm looking for a arduino compatible ATtiny that has 3 independent PWM channels to run the simplest of code below for a mood lamp. I can use a spare ATmega8 I have but it seems such a waste of chip and PCB space. I'm not bothered about a bootloader as long as I can program the chip using ArduinoISP. Is the 8 pin ATtiny85 suitable or any suggestions please?
// HLSMAX BEST IF DIVISIBLE BY 6. RGBMAX, HLSMAX must each fit in a byte.
#define HLSMAX 240                              // H,L, and S vary over 0-HLSMAX
#define RGBMAX 255                              // R,G, and B vary over 0-RGBMAX
#define RedPin 3
#define GreenPin 6
#define BluePin 9
const long mainDelay = 25;                      // Delay between each colour change
byte R,G,B;                                     // Target RGB colour
byte Ro,Go,Bo;                                  // Current RGB colour
// Serial.begin(9600);
    pinMode(RedPin,OUTPUT);
    pinMode(GreenPin,OUTPUT);
    pinMode(BluePin,OUTPUT);
    for (word Hue=0; Hue <= HLSMAX; Hue++){     // Once around the circle
        HLS2RGB(Hue,HLSMAX,HLSMAX/2);           // Get target R,G,B colour
// Serial.print (Hue);
// Serial.print (" = ");
// Serial.print (R,16);
// Serial.print (",");
// Serial.print (G,16);
// Serial.println (B,16);
        boolean OK = false;                     //Flag colours don't match
        while (OK == false){
            long loopTime = millis();           //Read timer
            while ((millis() - loopTime) < mainDelay) {}    // Delay
            OK = true;                          // Flag colours match
            if (R > Ro){                        // Target R greater than current Ro
                Ro++;                           // Increment current
                OK = false;                     // Flag colours will change
            if (R < Ro){                        // Target R less than current Ro
                Ro--;                           // Decrement current
            if (G > Go){
                Go++;
                OK = false;
            if (G < Go){
                Go--;
                OK = false;
            if (B > Bo){
                Bo++;
                OK = false;
            if (B < Bo){
                Bo--;
                OK = false;
            analogWrite(RedPin,Ro);
            analogWrite(GreenPin,Go);
            analogWrite(BluePin,Bo);
void HLS2RGB(word hue, word sat, word lum) {
    word M1,M2;                                 // calculated numbers
    sat = constrain(sat, 1, HLSMAX);            // Don't allow sat<=0 or sat>HLSMAX
    lum = constrain(lum, 0, HLSMAX/2);          // Don't allow lum<0 or lum>(HLSMAX/2)
    if (lum <= (HLSMAX/2))
        M2 = (lum*(HLSMAX + sat) + (HLSMAX/2))/HLSMAX;
        M2 = lum + sat - ((lum*sat) + (HLSMAX/2))/HLSMAX;
    M1 = 2*lum-M2;
    // get RGB, change units from HLSMAX to RGBMAX
    R = (Hue2RGB(M1,M2,hue+(HLSMAX/3))*RGBMAX +(HLSMAX/2))/HLSMAX;
    G = (Hue2RGB(M1,M2,hue)*RGBMAX + (HLSMAX/2)) / HLSMAX;
    B = (Hue2RGB(M1,M2,hue-(HLSMAX/3))*RGBMAX +(HLSMAX/2))/HLSMAX;
    //return(RGB(R,G,B));
// Utility routine for HLS2RGB
byte Hue2RGB(word m1, word m2, word hue) {
    // range check: note values passed add/subtract thirds of range
    if (hue < 0)
        hue += HLSMAX;
    if (hue > HLSMAX)
        hue -= HLSMAX;
    // return r,g, or b value from this tridrant
    if (hue < (HLSMAX/6))
        return ( m1 + (((m2-m1)*hue+(HLSMAX/12))/(HLSMAX/6)));
    if (hue < (HLSMAX/2))
        return ( m2 );
    if (hue < ((HLSMAX*2)/3))
        return ( m1 + (((m2-m1)*(((HLSMAX*2)/3)-hue)+(HLSMAX/12))/(HLSMAX/6)));
        return ( m1 );
Hi!
Attiny85 will work fine.
I use a Attiny85 in a mood lamp I made for my kids. 3*PWM pins to control the RGB-LED.
Used a extra photoresistor to sense when it is dark/light in the room to automatically turn on/off the lamp.
You can program the chip using ArduinoISP.
/Olof
Riva:
The ATtiny85 should work perfectly.
Does the ATtiny85 have 3 independent PWM channels? This image from one of the core suppliers only shows 2
The parametric search says it has 6 PWM's but does the Arduino cores support more than 2.
Riva:
Yes.
The image is wrong.
This core supports all three...
http://code.google.com/p/arduino-tiny/
Riva:
The Tiny85 has two 8-bit timers so it can do 4 PWMs. I don't know where the number 6 comes from.
Thanks Guys,
ATtiny85's ordered. I might be back later if I'm having problems though :smiley:
Riva:
For anyone referencing this thread in the future the link Coding Badly supplied http://code.google.com/p/arduino-tiny/ for a ATtiny85 core supports 3x PWM on digital pins 0,1 & 4
Riva:
That image has a lot of missing info...
The three PWM outputs are OC0A 0C1A and OC1B.
