Attiny - Tinywire send strings
Hello,
I have been trying to get a Attiny85 (running as master) to talk to a arduino UNO (running as slave) over the I2C bus. I have the TinyWire library running on the Attiny. I can get the Attiny to send a single byte to the arduino by running this code:
#include <TinyWireM.h>
  TinyWireM.begin();
byte x = 0;
  TinyWireM.beginTransmission(4);
  TinyWireM.send(x);
  TinyWireM.endTransmission();
  x++;
But when I run this code to send a string to the Arduino:
  TinyWireM.begin();
  TinyWireM.send("Hello world");
I get this error:
Tiny85_Temp.pde: In function ‘void loop()’:
Tiny85_Temp:9: error: invalid conversion from ‘const char*’ to ‘uint8_t’
Tiny85_Temp:9: error: initializing argument 1 of ‘void USI_TWI::send(uint8_t)’
Any help would be appreciated
Thanks in advance
Nathan
I think you will need to write a loop to send each character in your string one at a time.
char myString[12] = "Hello world";
for(byte i = 0; i <= strlen(myString); i++)
  { TinyWireM.send(myString[i]); }
The "uint8_t" in your error message is a byte (unsigned 3-bit). Take a look at the source code for the send function call in TinyWireM library.
Best to declare the variables you need to send using a Union, and then just send them (text, long, float, short, etc.) as bytes, one byte at a time.
http://www.pvtuts.com/cpp/cpp-struct-union
Hope that helps.
borland:
More than one way to skin a cat. You could use pointers instead of a union:
Serial.begin(38400);
  char myVar = 'A';
  Serial.print("char ");
  char* ptr = (char*)&myVar; // get a pointer to any data type: char, byte, int, long, float, string
  for(byte i=0; i < sizeof(myVar); i++) // for each byte in myVar,
    Serial.print((byte)*ptr); Serial.print(" "); // output one byte
    ptr++; // point to the next byte
  Serial.println("");
  byte myVar = 128;
  Serial.print("byte ");
  Serial.println("");
  int myVar = 258;
  Serial.print("int ");
  Serial.println("");
  long myVar = 65538;
  Serial.print("long ");
  Serial.println("");
  float myVar = 1.1;
  Serial.print("float ");
  Serial.println("");
  char myVar[16] = "Hello, world";
  Serial.print("string ");
  Serial.println("");
Serial.println("");
