I am building a metal detector from a project seen on the internet. It uses a Nano board and below is the code.
But I want to use an Attiny85 and obviously the code has to be changed
First I changed the port numbers and found it would not compile.
Then I changed the #define to const int.
Then it compiled but the project still would not work producing no buzzer output.
Is there anything else that I should change in the code to make it work on an Attiny 85
Thanks for any assistance
#define capPin A5
#define buz 9
#define pulsePin A4
#define led 10
long sumExpect=0; //running sum of 64 sums
long ignor=0; //number of ignored sums
long diff=0; //difference between sum and avgsum
long pTime=0;
long buzPeriod=0;
pinMode(pulsePin, OUTPUT);
digitalWrite(pulsePin, LOW);
pinMode(capPin, INPUT);
pinMode(buz, OUTPUT);
digitalWrite(buz, LOW);
pinMode(led, OUTPUT);
int minval=1023;
int maxval=0;
long unsigned int sum=0;
for (int i=0; i<256; i++)
//reset the capacitor
pinMode(capPin,OUTPUT);
digitalWrite(capPin,LOW);
delayMicroseconds(20);
pinMode(capPin,INPUT);
applyPulses();
//read the charge of capacitor
int val = analogRead(capPin); //takes 13x8=104 microseconds
minval = min(val,minval);
maxval = max(val,maxval);
sum+=val;
long unsigned int cTime=millis();
char buzState=0;
if (cTime<pTime+10)
if (diff>0)
buzState=1;
else if(diff<0)
buzState=2;
if (cTime>pTime+buzPeriod)
if (diff>0)
buzState=1;
else if (diff<0)
buzState=2;
pTime=cTime;
if (buzPeriod>300)
buzState=0;
if (buzState==0)
digitalWrite(led, LOW);
noTone(buz);
else if (buzState==1)
tone(buz,2000);
digitalWrite(led, HIGH);
else if (buzState==2)
tone(buz,500);
//subtract minimum and maximum value to remove spikes
sum-=minval;
sum-=maxval;
if (sumExpect==0)
sumExpect=sum<<6; //set sumExpect to expected value
long int avgsum=(sumExpect+32)>>6;
diff=sum-avgsum;
if (abs(diff)>10)
sumExpect=sumExpect+sum-avgsum;
ignor=0;
ignor++;
if (ignor>64)
sumExpect=sum<<6;
ignor=0;
if (diff==0)
buzPeriod=1000000;
buzPeriod=avgsum/(2*abs(diff));
void applyPulses()
for (int i=0;i<3;i++)
digitalWrite(pulsePin,HIGH); //take 3.5 uS
delayMicroseconds(3);
digitalWrite(pulsePin,LOW); //take 3.5 uS
