Attiny13 Clock frequency and ADC
I am working with an Attiny13 AVR, which is programmed by arduino UNO over SPI.
I found a core for attiny13 and the content of the boards.txt file as follows;
#attiny13.name=Attiny13 @ 128 KHz (internal watchdog oscillator)
#attiny13.upload.using=arduino:arduinoisp
attiny13.upload.protocol=avrispv2
attiny2313at1.upload.using=pololu
#attiny13.upload.maximum_size=1024
#attiny13.upload.speed=250 # important for not losing connection to a slow processor
#attiny13.bootloader.low_fuses=0x7B
#attiny13.bootloader.high_fuses=0xFF
#attiny13.bootloader.unlock_bits=0x3F
#attiny13.bootloader.lock_bits=0x3F
#attiny13.build.mcu=attiny13
#attiny13.build.f_cpu=128000
#attiny13.build.core=core13
attiny13a.name=Attiny 13A standalone 128khz
attiny13a.upload.using=arduino:arduinoisp
attiny13a.upload.maximum_size=1024
attiny13a.maximum_data_size=64
attiny13a.upload.speed=19200
attiny13a.bootloader.low_fuses=0x7b
attiny13a.bootloader.high_fuses=0xFF
attiny13a.bootloader.path=empty
attiny13a.bootloader.file=empty
attiny13a.bootloader.unlock_bits=0xFF
attiny13a.bootloader.lock_bits=0xFF
attiny13a.build.mcu=attiny13
attiny13a.upload.tool=avrdude
attiny13a.build.f_cpu=128000L
attiny13a.build.core=core13
attiny13f.name=Attiny 13A standalone 600khz
attiny13f.upload.using=arduino:arduinoisp
attiny13f.upload.maximum_size=1024
attiny13f.maximum_data_size=64
attiny13f.upload.speed=19200
attiny13f.bootloader.low_fuses=0x69
attiny13f.bootloader.high_fuses=0xFF
attiny13f.bootloader.path=empty
attiny13f.bootloader.file=empty
attiny13f.bootloader.unlock_bits=0xFF
attiny13f.bootloader.lock_bits=0xFF
attiny13f.build.mcu=attiny13
attiny13f.upload.tool=avrdude
attiny13f.build.f_cpu=600000L
attiny13f.build.core=core13
attiny13c.name=Attiny 13A standalone 1.2mhz
attiny13c.upload.using=arduino:arduinoisp
attiny13c.upload.maximum_size=1024
attiny13c.maximum_data_size=64
attiny13c.upload.speed=19200
attiny13c.bootloader.low_fuses=0x6a
attiny13c.bootloader.high_fuses=0xFF
attiny13c.bootloader.path=empty
attiny13c.bootloader.file=empty
attiny13c.bootloader.unlock_bits=0xFF
attiny13c.bootloader.lock_bits=0xFF
attiny13c.build.mcu=attiny13
attiny13c.upload.tool=avrdude
attiny13c.build.f_cpu=1200000L
attiny13c.build.core=core13
attiny13d.name=Attiny 13A standalone 4.8Mhz
attiny13d.upload.using=arduino:arduinoisp
attiny13d.upload.maximum_size=1024
attiny13d.maximum_data_size=64
attiny13d.upload.speed=19200
attiny13d.bootloader.low_fuses=0x79
attiny13d.bootloader.high_fuses=0xFF
attiny13d.bootloader.path=empty
attiny13d.bootloader.file=empty
attiny13d.bootloader.unlock_bits=0xFF
attiny13d.bootloader.lock_bits=0xFF
attiny13d.build.mcu=attiny13
attiny13d.upload.tool=avrdude
attiny13d.build.f_cpu=4800000L
attiny13d.build.core=core13
attiny13e.name=Attiny 13A standalone 9.6Mhz
attiny13e.upload.using=arduino:arduinoisp
attiny13e.upload.maximum_size=1024
attiny13e.upload.speed=19200
attiny13e.maximum_data_size=64
attiny13e.bootloader.low_fuses=0x7A
attiny13e.bootloader.high_fuses=0xFF
attiny13e.bootloader.path=empty
attiny13e.bootloader.file=empty
attiny13e.bootloader.unlock_bits=0xFF
attiny13e.bootloader.lock_bits=0xFF
attiny13e.build.mcu=attiny13
attiny13e.upload.tool=avrdude
attiny13e.build.f_cpu=9600000L
attiny13e.build.core=core13
When I am programming the attiny13, I select the "Attiny 13A standalone 9.6Mhz" as target board.
So, I expect it to run at 9.6Mhz.
I set the TCCR0B register as follows to get No "prescaling"
TCCR0B |= _BV(CS00);
TCCR0B &= ~_BV(CS01);
TCCR0B &= ~_BV(CS02);
Also set the PWM mode as "Fast PWM" by changing the TCCR0A register.
TCCR0A |= _BV(WGM00);
TCCR0A |= _BV(WGM01);
TCCR0A &= ~_BV(WGM02);
With those settings I should get 9.6Mhz/256 = 37.5 Khz PWM frequency. However, when I connect the output of the PWM to a MOSFET for driving and LED strip, I get and audible buzzing from the MOSFET.
That prompt me to think that my clock is not running at 9.6Mhz, since 37.5Khz is not an audible frequency.
So, I did another quick search on the topic of clock frequency and found the following webpage;
If I didnt get it wrong, this page says that my clock frequency is divided by 8 by default.
To be able to get no divisor, I need to reset all the bits.
I did so and reseted all the CLKPS bits.
CLKPR = (1<<CLKPCE);
CLKPR = (0<<CLKPS3) | (0<<CLKPS2) | (0<<CLKPS1) | (0<<CLKPS0);
So, in theory, I should get 9.6Mhz clock frequency with the divisor of 1.
When I use all those aforementioned settings, I no more hear a buzzing sound.
My first question is; Am I correct with all those settings?
However, another problem emerged this time.
I use a potentiometer for controlling the brightness. When set the clock divisor to "1", behaviour of the potentiometer changed. Analog input does not read a value right away when I turned the potentiometer, so I need to turn it a little more to get the minimum brightness and it reaches to maximum brightness before I reach to other end of the potentiometer. So, I believe there is something wrong with the ADC.
Second question is; how might this clock divisor setting be affecting the ADC port? There must be a relationship. However, does that affect the voltage reading range of the ADC?
When I am programming the attiny13, I select the "Attiny 13A standalone 9.6Mhz" as target board. So, I expect it to run at 9.6Mhz.
After executing Tools / Burn Bootloader. You have to change the fuses. Tools / Burn Bootloader does that.
Thanks for your reply.
Under the Analog to Digital Converter title I found the following information;
By default, the successive approximation circuitry requires an input clock frequency between 50 kHz and 200 kHz to get maximum resolution. If a lower resolution than 10 bits is needed, the input clock frequency to the ADC can be higher than 200 kHz to get a higher sample rate.
So, my clock frequency is 9.6Mhz and I need to set a prescaler in between 9.6Mhz/20Khz= 48 and 9.6Mhz/50Khz = 192 for the ADCSRA register.
I selected the division factor of 128, which requires setting all three bits ADPS2, ADPS1 and ADPS0.
ADCSRA != 1<< ADPS2;
ADCSRA != 1<< ADPS1;
ADCSRA != 1<< ADPS0;
This should set all three bits and keep the frequency of the ADC in between 50Khz - 200Khz.
However, I still get the same behaviour from the potentiometer.
Where am I wrong?
Typically, the core correctly initializes the analog-to-digital converter's clock. Is that not the case for the core you are using?
None of those have side-effects.
